Logging wideband
Old May 1, 2018 | 08:20 AM
Nelson Ninham's Avatar
Logging wideband
I have a aem ugeo and am having a real hard time getting the wideband to read properly through the o2 sensor number 2 position!
Old May 1, 2018 | 11:49 PM
huzzle101's Avatar
I don't have a suggestion for you but can i ask you when you use the number 2 position, does that mess up anything in the ECU, do you have to disable anything. Im trying to figure out where to install my AFR sensor.
Old May 2, 2018 | 08:53 AM
02 number 2 is disabled that is not the location of my wideband 02. im only using the signal wire as the tap for my wideband to log the wideband through that wire.
Old May 2, 2018 | 09:09 AM
huzzle101's Avatar
Did you bung a new location for your O2 ?
Old May 2, 2018 | 09:17 AM
jingalalahoe's Avatar
follow the instructions from this thread.
https://www.evolutionm.net/forums/la...o-evoscan.html
In my case, the formula given did not give me the same readings as the wideband guage, I had to modify it a bit but it works flawless for me.
Old May 2, 2018 | 10:24 AM
Biggiesacks's Avatar
some widebands need to have their outputs configured, so that might be an issue, also make sure you aren't using a narrowband simulation output.
xPRimNT
157
Dec 26, 2018 08:09 AM
Edik_898_
Nov 28, 2016 02:02 PM
jcsbanks
Jan 19, 2008 09:01 AM
w8less1der
12
Dec 9, 2004 07:32 AM
