ECU FLASH Tuning Questions
Old May 10, 2006 | 07:06 PM
MalibuJack's Avatar
Most interesting is the "Lean spool enable" which allows you to improve your turbo's spool..
Old May 10, 2006 | 07:08 PM
MalibuJack's Avatar
Originally Posted by anjapower
why can't I download any roms from openecu.org? I see the 3 ROM threads in "Evo 8" forum but there's no link to download from?
You have to be logged in..
Hopefully when we get a forum here, I'll ask everyone to contribute their roms and I can put them all in a directory on my server that anyone can access..
05BlackEVO's Avatar
i havent tried this yet, but im wondering if i can save the stock program on the pc from the car and view it later or just to have ( warranty purposes)?
Old May 10, 2006 | 07:10 PM
MalibuJack's Avatar
Absolutely, thats half of its value..
Old May 10, 2006 | 07:14 PM
l2r99gst's Avatar
I did just that right now. Plugged in the cable and used the latest ECUFlash to download my stock 05 Evo ROM.
Should we get a new thread for just ROMs?
Anyway, I was looking through all of the tables and everything looks great. The stock Evo runs so rich from the factory, it's ridiculous.
Anyway, I have a quick question for someone who knows these maps a little better. Which one is the one to alter to eliminate fuel cut? Fuel cut in Mitsus is usually proportional to some load value, somewhat proportional to a mass airflow/rev.
I think one of the definitions may be it, but I thought I would ask to make sure.
Thanks,
Eric
Old May 10, 2006 | 07:15 PM
anjapower's Avatar
Gotcha
Old May 10, 2006 | 07:20 PM
MalibuJack's Avatar
Thanks,
Eric
To answer your questions in order..
Congrats, that was also the first thing I did..
I suggest to create a thread just for roms, but they have to be OEM or self-tuned, and the mods have to allow zip uploads of 150k (approx) which I don't know is configured in this forum.
I didnt clearly see a table that directly associated with fuel cut.. It could be one of the load maps (single columns) but I haven't figured it out yet.. Or its just not defined yet in the files and it'll be added later.
Old May 10, 2006 | 07:25 PM
b0ostedEV08's Avatar
The 2005 EVO 8 only has 1 ROM for that year model. Which is ROM JM96940011
And ECU# 1860A118 which the software already have in the database. So it's no need to post that ROM Image.
Old May 10, 2006 | 07:30 PM
l2r99gst's Avatar
Yep, 96940011 is the one I just downloaded. The upload limit in this forum is only 100K anyway, so we need it upped a little to upload our ROMs.
Eric
Old May 10, 2006 | 07:33 PM
The cut is referred as Boost Limit Table and Boost Cut Delay Timer data value.
Old May 10, 2006 | 07:34 PM
l2r99gst's Avatar
That's the table I was thinking, but I didn't want to mention it before I knew for sure. The table has values like 245 and 235. What are those referencing...load values?
Thanks,
Eric
Old May 10, 2006 | 07:36 PM
DynoFlash's Avatar
Thanks,
Eric
the fuel cut is two parts
"boost limit" which is the threshold which you can go up to before it cuts
and
"boost delay timer" which is the amount of time the boost is allowed to go over the "boost limit" value before the fuel cuts
You can either just jack them both up all the way and basically elimainate fuel cut 100% or you can just raise it enough to stop the car from cutting as you have it tuned which retains some over boosting protection
Thanks,
Eric
Correct
Old May 10, 2006 | 07:37 PM
MalibuJack's Avatar
Okay.. I see both of them.. The rom I'm using shows the boost cut delay timer as being invalid for ECU MN132874 JM9417
Also the definition file should also have the immobilizer section added since having it written down somewhere will also help if you accidentally flash your ECU with someone elses.
Old May 10, 2006 | 07:39 PM
I will fix that problem with JM9417 ROM. Also me and Colby talked today about adding the immobilizer section... hehe
