Caution - "Knock Sensor Filters"
The ecu's knock detection is quantitative, there is no qualitative measurment. It sucks. Majority of my knock is in closed loop, with stock engine parts.
I think the best way to tune for knock without a gas bench would consist of having the sensor hooked up to the amp with headphones somehow.
Also, never use "knock volts" as reliable data, it's not a linear output. Several years ago even competent tuners mistakenly tuned by this.
Those are values that some of the clever folks here will eventually crack. Thinking the 12 filter maps are separated into 4 - 5 different catagories (relating somehow to CA, freq, noise level not during combustion, etc)
Many have suspected that these "knock filters" are nothing to do with knock control. Mattjin has found that some are related to fan control. Having now disassembled the knock control routines, I can confirm that these so called "knock filters" are nothing of the sort. They should be relabelled.
I suggest de-stickying this thread.
Live4Redline
Jul 17, 2024 07:09 AM
