Boost question
Old May 28, 2006 | 09:45 PM
JeffR116's Avatar
Originally Posted by MalibuJack
You can use an MBC and set it manually to 19psi (or any reasonable setting for that matter) or you can alter the settings in the ECU to remove the tapering feature.
Actually Jack, a MBC will not let you hold boost solid to redline, even at 19 psi. I know, because I have one.
People are preaching that the stock turbo just "isnt efficient" enough to hold boost to redline, but that's a lie. The turbo is plenty efficient, and will hold a max of about 26psi to redline before running into efficiency issues.
The only proven method I have seen that allows you to hold boost solidly through all gears and rpms is upgrading the wastegate actuator.
Old May 28, 2006 | 11:51 PM
vboy425's Avatar
what kind of waste gate actuator are you talking about anway ? is it forge??
Old May 29, 2006 | 06:15 AM
MalibuJack's Avatar
It depends on ALOT of factors, but I do have an MBC on my car that holds a solid 21psi through redline. I do prefer closed loop electronic boost control however..
And the stock actuator can easily hold 21 psi (and more in some configurations).. Most actuators have not been correctly preloaded which is likely the reason why they aren't holding correctly. Also, 80% of the cars have other issues, boost leaks, inadequate signal to the DV causing it to open early, insufficient spring pressure in the DV, etc..
h4ckluserr
10
Dec 7, 2015 09:32 PM
maperformance
Dec 16, 2014 04:57 PM
flippymcbean
May 5, 2014 11:45 AM
Andrew@AMS
Automotosports - Illinois
Sep 18, 2012 07:01 AM
KevinD
Nov 2, 2009 04:46 PM
