What to use for DataLogging
Originally Posted by mchuang
Oh yea lol and I definetly don't know how you have more timing than me. It is suppose to decrease as the boost goes up not increase. Every ignition map I have ever seen or used on any of my cars has a sort of step retard in timing even the stock map when I looked at it, but my mail in has like 8 degrees straight across the board from 160% load point to 260% load point and yours was 9 straight across with more boost that was when I was like something aint right. It was good for removing the stock restrictions at least though.
As the engine spins faster, you need to increase the timing in order to allow the combustion to create pressure in time to transfer enough of its energy (expanding gases) to the piston's downstroke. Timing and Fuel are interelated, since the leaner you run, the less fuel there is to completely burn, and therefore the less timing you can run.. So it becomes a bit of a balance on several levels since this also affects exhaust gas temps which can melt parts too.
The difference is, on a normally aspirated motor of a similar design, you may find the timing to be significantly higher than with a turbocharger..
Old school MSD boxes designed for supercharging have something called a boost timing retard, since the base timing and advance timing are all vacuum/counterweight, and mechanically controlled, so when you hit boost, you need to remove a bit of timing from it.. Comparing different turbocharged variations on the same type of car makes it not as obvious about the timing, but I've seen 32 degrees of timing used on normally aspirated engines.. Cylinder pressure is what your aiming for, you want to produce a burn where the cylinder pressure is building just after top dead center, most of the time, as you increase the effective compression ratio (Boost) you have to give it more time to create a burn that will produce the best power. There's a little more to it since AFR's aren't 100% about getting a complete burn, but providing a method of also absorbing excess heat hence why you run rich..
Originally Posted by MalibuJack
If you were to compare two similar motors with and without a turbo, or with two levels of boost, you would see the differences in timing more clearly..
Fortunately his through the mail tunes are safe enough that there's really no need to be concerned about it.
Originally Posted by PDXEvo
I disagree. There is no excuse for laziness! Duping the map creates a potential failure point that could cost someone their car. The stock maps are even safer, yet you see that they differ the maps, so this is just a stupid thing to think.
Lol calm down, I definetly agree with you, but its not like malibu made the flash.
Posted some ECU+ logs in my EcuFlash thread if you all want to see what the ECU+ logs look like:
https://www.evolutionm.net/forums/sh...0&postcount=13
No, but malibu is a lot smarter then that. I am a little disappointed in him. Crazy Malibu! Whoops, off topic, sorry!
Originally Posted by TTP Engineering
I really hate the overlapped view. The individual logs are so much cleaner.
Originally Posted by Jorge T
They are cleaner but they loose so much resolution. I really like the way the zeitronix integrates with the knock buffer.
looks like evoscan is coming along pretty good....we might actually have a decent logger in a few weeks. Then I can actually make some changes with ecuflash, right now my cable just sits...well I did raise my idle rpms this weekend, about all I can do at this point that is safe
