How much timing are you running on pump gas?
Old Jun 18, 2006 | 02:00 PM
anjapower's Avatar
How many degrees of timing are you running on pump gas?
I looked at a friend's tune this past weekend and he was running 10! degrees more timing at 7500 and 23 PSI than me. Is my tune just not very aggressive or is his just too aggressive?
Here's my timing map for the boost columns. Comments, Opinions?
Mods - 05 Evo:
GSC 272/272
Helix Turboback (catless)
Helix Intake
Forge Recirc Valve
Hallman MBC
Walbro Fuel Pump
Ebay 02
Turboxs FMIC
LPI LICP
Ported Manifold
Ported Hotside
Reflashed ECU
Works Throttle Body
Stock Plugs
93 Oct Pump gas
Old Jun 18, 2006 | 02:36 PM
Noogles's Avatar
i run 22 degrees on pump
Old Jun 18, 2006 | 03:07 PM
anjapower's Avatar
in what boost column and at what RPM?
Old Jun 18, 2006 | 03:12 PM
elhalisf's Avatar
RPM Timing
2500 9
3000 9
3500 10
4000 10
4500 10
5000 11
5500 11
6000 11
6500 13
7000 17
7500 19
11000 22
Old Jun 18, 2006 | 04:20 PM
Noogles's Avatar
Load 260
rpm 7000
Old Jun 18, 2006 | 04:30 PM
anjapower's Avatar
Load 260
rpm 7000
wow...11 more degrees of timing than me. No wonder why my car's performance is
Old Jun 18, 2006 | 04:50 PM
4TUN8's Avatar
I don't run that ****ing much that's for sure.
Old Jun 18, 2006 | 05:25 PM
taenaive's Avatar
It all depends on cars and set up. I discovered that my car likes low timing and lean tune than rich and high timing tune. it was about 40 WHP difference.
Old Jun 18, 2006 | 05:36 PM
djmikeymike's Avatar
i dont have anything below 8 degrees from 160 to 260 load and 19 degrees is the highest @7500...... this is my mail in on 93 pump
Old Jun 18, 2006 | 06:37 PM
chmodlf's Avatar
My timing at 7K and 260 load is 14.
Old Jun 18, 2006 | 06:46 PM
AlwaysinBoost's Avatar
3" TBE, K&N panel filter, walbro 255lph, on 93 octain with 1.45 max boost (spike in 5th) this is my everyday timing map:
and here is what my fuel map looks like to go along with it.
that exact map I trapped 107 at the track in 90* heat with a little less boost in my 04 GSR.
Old Jun 18, 2006 | 09:30 PM
Noogles's Avatar
That was on the stock turbo.
On my 37r i'm running 14 degrees but i haven't gotten on the dyno for a full tune yet.
Old Jun 19, 2006 | 01:41 AM
elhalisf's Avatar
can you post a bigger picture of your fuel map. i cant read the a/f numbers in blue. thanx
Old Jun 19, 2006 | 06:59 AM
Girlie's Avatar
Does your friend have stock cams?
Girlie
Old Jun 19, 2006 | 07:29 AM
anjapower's Avatar
Girlie
no he has buddy club cams 264/272 set at -2/-2
