knock problem spot at 3,000 rpm......
Old Jun 22, 2006 | 09:03 AM
MalibuJack's Avatar
Originally Posted by mad_VIII
Hey Jack,
We talked about the mod maf value on the utec forum a couple weeks ago. I thought the conclusion was the utec was not modifying the maf value but rather the mod maf column was reporting a few milliseconds after the maf column. This was one my original concerns when I started logging for the reflash. Utec is in passthrough mode.
If someone can advise on how to rescale the load columns I would be glad to give it a try.........
It is.. But that value at 3000-4000rpm (1000-1200hz) is 30% higher than stock and way outside the 260% column..
Old Jun 22, 2006 | 09:29 AM
Mad_SB's Avatar
Ohh, right on, I did not realise that you could edit the axis in the maps!!!!
Cool I will get on that today.
Thankx folks!
Old Jun 22, 2006 | 09:31 AM
MalibuJack's Avatar
Thankx folks!
I didn't realize it until 2 days ago either.. Completely overlooked that it was possible.. I know others have done that and had success.. My results were inconclusive due to the car I was testing it on..
Old Jun 22, 2006 | 11:31 AM
Mad_SB's Avatar
I will work on it tonight when I get home, ... ohh wait, I forgot I had my laptop and map with me today..... maybee I will get it done before I leave today and try it out tonight.
Old Jun 22, 2006 | 06:24 PM
Mad_SB's Avatar
Good news, map scaling solved my issues
Well,
Thanks to all who advised I should scale the load on the timing and fuel maps... worked like a champ.
So, I followed the ralliart method and removed two lower columns from each map and added a 280 and and 300 column. Results are great!! One interesting thing though, it seems the stock ecu was using timing values from outside the map more often than the runs were actually falling out side the map, hard to explain, but even though i only seemed to fall into the 280 column once in this run, the timing values were much more stable than pre scaling.
So without further delay here are the map shots and tonights log:
RPM, MAP, MAF,TPS,Site,Count, Ign#1, Inj#1, Ign, Fuel,Boost, MAF, AFR
2052, -1.7, 274, 56, 10, 00, +16.1, 9.6,ECU. , +0.0,ECU. , 261, 15.02
2109, +0.0, 291,100, 10, 00, +13.3, 11.9,ECU. , +0.0,ECU. , 307, 14.58
2211, +1.2, 269,100, 10, 00, +12.3, 11.9,ECU. , +0.0,ECU. , 257, 13.72
2278, +2.1, 326,100, 10, 00, +12.3, 13.3,ECU. , +0.0,ECU. , 299, 12.93
2345, +2.9, 282,100, 10, 00, +11.3, 15.3,ECU. , +0.0,ECU. , 315, 12.64
2424, +3.3, 315,100, 10, 00, +10.3, 15.4,ECU. , +0.0,ECU. , 319, 12.37
2496, +4.1, 388,100, 10, 00, +9.2, 18.6,ECU. , +0.0,ECU. , 376, 12.21
2598, +4.5, 436,100, 10, 00, +8.2, 17.6,ECU. , +0.0,ECU. , 391, 12.06
2683, +5.2, 395,100, 10, 00, +7.5, 19.1,ECU. , +0.0,ECU. , 447, 11.92
2773, +6.0, 581,100, 10, 00, +6.8, 20.3,ECU. , +0.0,ECU. , 420, 11.89
2876, +6.9, 547,100, 10, 00, +4.8, 23.4,ECU. , +0.0,ECU. , 459, 12.18
3003, +8.1, 559,100, 10, 00, +5.1, 25.9,ECU. , +0.0,ECU. , 682, 12.18
3083, +9.5, 528,100, 10, 00, +4.8, 32.9,ECU. , +0.0,ECU. , 570, 11.73
3205,+11.0, 572,100, 10, 00, +4.8, 38.1,ECU. , +0.0,ECU. , 593, 11.58
3343,+12.9, 704,100, 10, 00, +5.9, 41.4,ECU. , +0.0,ECU. , 673, 11.58
3497,+14.8,1006,100, 20, 00, +5.6, 48.5,ECU. , +0.0,ECU. , 929, 11.49
3646,+17.0,1128,100, 30, 00, +5.6, 49.7,ECU. , +0.0,ECU. ,1098, 11.42
3770,+19.1, 954,100, 30, 00, +5.7, 51.4,ECU. , +0.0,ECU. ,1084, 11.34
3940,+20.1,1046,100, 40, 00, +5.6, 51.8,ECU. , +0.0,ECU. ,1285, 11.28
4089,+20.8,1340,100, 40, 00, +6.2, 57.5,ECU. , +0.0,ECU. ,1173, 11.27
4251,+21.0,1219,100, 40, 00, +6.2, 59.3,ECU. , +0.0,ECU. ,1008, 11.23
4357,+21.0,1070,100, 40, 00, +6.0, 60.5,ECU. , +0.0,ECU. ,1121, 11.17
4535,+21.3,1237,100, 50, 00, +6.3, 60.7,ECU. , +0.0,ECU. ,1057, 11.14
4668,+21.3,1196,100, 50, 00, +6.6, 59.8,ECU. , +0.0,ECU. ,1173, 11.14
4823,+21.3,1234,100, 50, 00, +6.3, 65.1,ECU. , +0.0,ECU. ,1400, 11.14
4945,+21.0,1392,100, 50, 00, +6.5, 67.9,ECU. , +0.0,ECU. ,1210, 11.14
5104,+21.0,1160,100, 60, 00, +6.3, 67.1,ECU. , +0.0,ECU. ,1506, 11.12
5241,+21.3,1445,100, 70, 00, +6.8, 72.8,ECU. , +0.0,ECU. ,1312, 11.08
5359,+21.3,1436,100, 80, 00, +7.9, 69.5,ECU. , +0.0,ECU. ,1457, 11.08
5482,+21.0,1515,100, 80, 00, +8.1, 74.5,ECU. , +0.0,ECU. ,1519, 11.14
5611,+20.5,1483,100, 80, 00, +8.1, 71.8,ECU. , +0.0,ECU. ,1543, 11.18
5698,+20.1,1369,100, 80, 00, +8.9, 75.2,ECU. , +0.0,ECU. ,1529, 11.18
5868,+19.6,1572,100, 80, 00, +10.2, 75.2,ECU. , +0.0,ECU. ,1432, 11.14
5973,+19.6,1547,100, 90, 00, +11.2, 74.1,ECU. , +0.0,ECU. ,1602, 11.08
6071,+19.6,1470,100, 90, 00, +11.3, 77.5,ECU. , +0.0,ECU. ,1628, 11.05
6172,+19.6,1515,100, 90, 00, +12.3, 80.0,ECU. , +0.0,ECU. ,1754, 11.05
6325,+19.8,1587,100, 90, 00, +12.4, 81.4,ECU. , +0.0,ECU. ,1552, 11.11
6410,+19.3,1529,100, 90, 00, +13.5, 80.7,ECU. , +0.0,ECU. ,1730, 11.05
6510,+18.4,1683,100,100, 00, +13.4, 81.7,ECU. , +0.0,ECU. ,1602, 11.02
6613,+18.2,1724,100,100, 00, +13.7, 80.4,ECU. , +0.0,ECU. ,1706, 11.01
6706,+18.2,1666,100, 90, 00, +14.6, 81.2,ECU. , +0.0,ECU. ,1515, 10.96
6802,+18.6,1644,100, 90, 00, +14.5, 80.2,ECU. , +0.0,ECU. ,1623, 10.99
6901,+19.1,1628,100,100, 00, +14.7, 83.7,ECU. , +0.0,ECU. ,1730, 10.99
7002,+18.9,1650,100,100, 00, +16.3, 82.9,ECU. , +0.0,ECU. ,1754, 11.01
7092,+18.4,1612,100,100, 00, +16.4, 87.7,ECU. , +0.0,ECU. ,1760, 10.96
7168,+17.7,1547,100,100, 00, +16.6, 78.5,ECU. , +0.0,ECU. ,1706, 10.89
7246,+17.4,1677, 96,100, 00, +16.5, 78.9,ECU. , +0.0,ECU. ,1416, 10.89
Old Jun 22, 2006 | 06:36 PM
AlwaysinBoost's Avatar
Is rescaling the columns as easy as just changing the # at the top? Sorry, I searched but didn't find a definative answer.
Old Jun 22, 2006 | 06:46 PM
andenbre's Avatar
that and all the data in the columns
Old Jun 22, 2006 | 06:48 PM
if that is the case, then I sure its already been addressed but, couldn't we add more resolution to the RPM range now?
Old Jun 23, 2006 | 05:54 AM
ScrappyJack's Avatar
Lightbulb
FWIW - The load scaling is not the same between the timing and fuel maps. I am assuming you want HOT, LOT, HOF, and LOF to all use the same load scaling.
Edit: Nevermind. I just had it pointed out to me that the factory timing and fuel column labels are not the same.
Old Jun 23, 2006 | 06:56 AM
Mad_SB's Avatar
Yes, The load columns between the fuel and timing maps are not the same.
In order to drop columns and two new ones, I looked for columns that were almost dead on interpolations between the lower and higher colums on either side of the ones i dropped. After plugging some numbers in the calculator (Cn + Cn+2) / 2 ~ Cn+1, I decided to drop columns 30 and 50 on the fuel map and 70 and 90 on the timing map.
CBRD
10
Apr 24, 2006 12:18 PM
WarmPepsi
Oct 2, 2005 08:11 PM
rraulston
28
Sep 21, 2005 09:55 AM
SlowCar
10
Aug 4, 2005 07:29 PM
Mad_SB
Apr 18, 2004 04:37 PM
