Evo 9 ignition maps
Old Jun 28, 2006 | 12:25 PM
Blak94GSX's Avatar
Originally Posted by andenbre
that is great info Blak94gsx. thank you very much. so in my case with a stock car with no injector, air intake, or turbo mods I will concentrate on map 2 and leave the others alone for safetys sake. even with the turbo back I will be installing i dont think its neccecary to mess with any thing other than 2
If you have to make drastic reductions to the timing on map 2, I would suggest doing similar things to the other maps for safety. Realistically though, we are almost always ADDing timing not REDucing timing so if anything, the defaults for maps 1 and 3 should be fine.
Old Jun 28, 2006 | 12:37 PM
jcsbanks's Avatar
I've had to retard my maps at 3000,3500,4000,6000,6500 all by 1 degree with 98 RON fuel, AFR 12:1 at 3000-3500, 11.5 or richer thereafter, 26 PSI peak, 24 PSI held midrange, then 22.5 PSI at 6000, 21 PSI at 7000. If I don't retard then if I get lift off det at 3000-4000, and some more in 6th gear at 6000-6500 RPM if the car is very hot. Probably a combination of low octane fuel, JDM map (3 degrees up on USDM approx) and a fair bit of boost?
domyz
Jul 27, 2022 11:54 AM
tephra
Sep 13, 2021 01:07 AM
PIE-R
Dec 21, 2019 08:14 PM
Jim in Tucson
Nov 21, 2010 09:29 AM
EriCS
Apr 19, 2010 09:43 AM
