engine feels like it hits a wall @ WOT
I've been trying to diagnose this problem for the last couple of days but can't seem to get a handle on it. What happens is @ 2k RPM when I go WOT boost will start to build and by @ 2.4k RPM it feels like I hit fuel cut as the engine kind of stalls for a second. my A/F is around 12.8-13.5:1 (depending on gear) and boost is like .2-.4bar (again depending on gear) when this happens.
SO far I've tried adjusting the accel enrichment values in that RPM range. Adding and removing timing in what I think is the load area (between 100-140). Change the target A/F number. I even tried to load the stock map back in but none of the above worked.
Anyone have any ideas?
running lean was my first guess also. I've set my target A/F richer then stock trying to fix the problem but that hasn't worked.
Plugs are NGK bpr7es (IIRC) gapped to .026. not sure why that would be the problem but I can throw the stockers back in to eliminate that as a possiblity
Originally Posted by TTP Engineering
I'd try closing the gap to .022
Originally Posted by Noogles
check your FPR, My stock one took a crap around 15k miles,
It wouldn't raise the Fuel pressure and i was going lean no matter how much fuel i added.
Originally Posted by Roberto
A/F is around 12.8-13.5:1?! on pump?! That is FAR leaner than I would feel safe running on pump, and would be damn borderline on C16 imho.
Originally Posted by PDXEvo
Im with TTP on this one. Sounds like you may be blowing out your spark.
sounds to me like a fault in your fuel system somewhere. Maybe the FPR as mentioned above...I had the exact same symptoms when I had the rubber gasket on my fuel pump slip out of place and was not getting adequate fuel pressure
