stock rom
Old Jun 28, 2006 | 08:11 PM
Ultimate CC's Avatar
stock rom
Where can i find a stock rom for a 2003 EVO MN132874
Old Jun 28, 2006 | 08:39 PM
MalibuJack's Avatar
Search for my post.. I have the same OE ECU and posted a bone stock rom...
Old Jun 28, 2006 | 10:08 PM
SubiEvolved's Avatar
we found it....
Jack,
check my UTEC post again please......
Old Jul 1, 2006 | 01:14 PM
scorke's Avatar
Can you link to the evo 8 stock rom, and also is this what I need to run/load to read the ecu?
Scorke
Old Jul 1, 2006 | 01:18 PM
MalibuJack's Avatar
http://www.aktivematrix.com/UTEC/03Evo-Stock.zip
That is the stock O3 Rom.. YOU MUST RETRIEVE YOUR IMMOBILIZER CODE FROM YOUR ECU'S MAP AND PUT IT INTO THE ROM before you flash it onto your car..
Old Jul 1, 2006 | 01:20 PM
MalibuJack's Avatar
Scorke
Try to read through the entire group of threads in this subforum.. The question your asking implies to me that your looking for the ECUFlash program, and some instruction on how to do it.. Please learn as much as you can before you modify your ECU...
Old Jul 1, 2006 | 01:24 PM
scorke's Avatar
Ok, I tried to connect it to read it already and got this message
[16:07:12.860] Version 1.28.716
[16:07:12.860] 8 memory models read.
[16:07:13.170] 71 ROM metadata models read.
[16:07:13.170] checksum module "subarudbw" loaded.
[16:07:13.170] flashing tool "wrx02" loaded.
[16:07:13.170] flashing tool "wrx04" loaded.
[16:07:13.170] flashing tool "sti04" loaded.
[16:07:13.170] flashing tool "sti05" loaded.
[16:07:13.170] flashing tool "mitsukernel" loaded.
[16:07:13.170] flashing tool "mitsukernelocp" loaded.
[16:07:13.170] flashing tool "mitsubootloader" loaded.
[16:07:13.170] error loading FTD2XX.DLL
[16:27:15.789] 262144 byte image read.
[16:36:21.784] 262144 byte image written.
[16:37:13.489] This vehicle interface does not support needed features.
[16:37:13.489] unable to connect to vehicle interface.
[16:44:27.132] 262144 byte image read.
Appreciate it jack, I know this isnt the thread for stuff like this but I appreciate it, and this is my dad's car, I am aware it won't work on mine that is ecutek'd.
Scorke
Old Jul 1, 2006 | 01:28 PM
MalibuJack's Avatar
You seem to have a driver problem... Also check to make sure your configuration setting for the port is for the OpenECU cable and not a COM port..
And I actually may have some new data on backing up a tune from a locked ECU..
Old Jul 1, 2006 | 01:33 PM
scorke's Avatar
Also jack PM that info/link/contact person if its you just lmk about that information about how to get info out of a locked ecu.
Scorke
Mattjin
Jun 6, 2019 10:50 AM
ReaperX
Oct 12, 2016 01:00 PM
paoloM
Lancer Engine Management / Tuning Forums
Jun 19, 2016 08:51 AM
airbus340
Nov 8, 2008 07:03 AM
honfui
Mar 9, 2007 02:07 AM
