Another method of displaying Evoscan 0.8 logs
Old Jul 8, 2006 | 05:25 AM
jcsbanks's Avatar
Load the csv into Excel - I'm sure you could do a macro to do the following: change the column heading for column A to "Time". Delete the date, time and seconds columns so that column B is the data proper, delete the empty wideband & DTC columns at the end, then resave as csv. Then you can load it into a demo version of a logging program for Subarus.
Old Jul 8, 2006 | 06:01 AM
MalibuJack's Avatar
The problem with using the first column for time, is anything that uses that time for calculations will be thrown off..
I created a macro to combine the time and seconds columns into one time column and load it into Data Log Lab (probably similar to what your looking at..)
Old Jul 8, 2006 | 04:52 PM
MalibuJack's Avatar
I decided to write a program instead.. The time method didn't work consistently and the formatting would not load correctly on my copy of Data Log Lab..
Old Jul 9, 2006 | 01:46 AM
jcsbanks's Avatar
The method I posted works well, see my logs I posted in the crazy timing thread.
Old Jul 9, 2006 | 06:58 AM
MalibuJack's Avatar
Yeah for some reason the time coded version didnt load properly in Data Log Lab.. When I rewrite it seconds from start of log, it can run for days and the logger tools should get both the sample and durations correct..
If I can get my act together, I may just log directly with my old dashboard app.. But I need to see sample code that works for me to do it.
Siege
Oct 24, 2016 08:06 AM
leecavturbo
Aug 31, 2010 02:13 AM
Thoe99
Nov 26, 2007 06:35 AM
JoeBee
Feb 22, 2007 05:37 AM
bbbwrx
Jun 3, 2006 09:12 AM
