alky injection + 2 low/high maps
Is there anyway to use ECU flash to use the high octane/advance timing maps to tune for alky and when alky is not present to switch to low octance (conservative map)?
I am trying to decide if I need to add more hardware to switch maps or if I can do it using existing hardware on the car.
Originally Posted by MalibuJack
No, but you can rescale your load axis and have a low boost tune, and high boost tune..
Sorry about all the dumb questions... I am trying to learn this so I don't buy a bunch of crap I don't need.
I'd like to run alky only when I want to and use straight pump the rest of the time. I don't want to have to leave my laptop in the car for those moments.
I know I can setup a maftpro to switch on the fly, but I am trying to avoid having to spend that $600 if possible.
Opinions are greatly appreciated!
No, but you can rescale you load axis and have a low boost tune, and high boost tune..
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I know this a mad old Thread but I'm trying to understand High/Low Oct maps. I'm planning on installing my FP red and my Aqaumist kit this weekend and want to get it tuned for low boost 18-23psi and my high boost up to 30psi but I will be spraying 50/50 or 100% and I don't want to have to mod the ECU with Tephra cause I don't want to loose the immobalizer feature of my ECU. I just want to be able to turn on the Aquamist turn up my EBC to 30psi and wham High map without worrying my car is going to explode...lol
If someone could explain the high/low map to me I would appreciate it. I currently have a high/low map flashed on my ECU for 93 oct and C16
Well, the #1 reason for using Tephras patch with alky is the failsafing. Personally, saving my engine and using the 'valet mode' to protect me from car theft is a wiser choice. If your not gonna use Tephras patch I suggest just running two seperate flashes like you are now.
