does ECUFlash work on Windows Mobile 5.0???
Old Jul 9, 2006 | 11:48 PM
housedj's Avatar
just curious to see if anyone has tried using their phone in place of a PDA for their datalogs & evoscans? my new t-mobile SDA has a 2GB mini SD card i picked up from the UK. it might not be enuff memory i'm thinking but might hold the major points of the ECUFlash (if it's compatible) until i get the 4GB sony ericsson W950i...
Old Jul 9, 2006 | 11:57 PM
Kings Fan's Avatar
Doubt it, you probably won't be able to install ecuflash or evoscan on wm5, Unless they decide to port it.
Old Jul 10, 2006 | 12:01 AM
housedj's Avatar
maybe if i store everything on the mini SD then load it into the phone??? it would be alot easier than carrying a laptop...
Old Jul 10, 2006 | 12:09 AM
Kings Fan's Avatar
That would be cool, I don't think it will work, wm5 is a different OS than windows xp/2000, the software won't be compatible unless they port it to wm5 os. You can copy all the system files onto the mini sd, but you won't be able to run them.
Old Jul 10, 2006 | 12:13 AM
housedj's Avatar
ahh. laptop it is...
Old Jul 10, 2006 | 07:26 AM
MalibuJack's Avatar
The development platform that Colby is using is capable of creating code for the PDA.. Only the cable needs a USB port and drivers, which I do not know exist yet for that platform..
EvoScan is a vb.NET application, and if the drivers work (as noted above), then this can also be ported without much difficulty..
Old Jul 10, 2006 | 10:48 PM
housedj's Avatar
i have a USB cable that came w/the phone so i can Active Sync to a PC, or i can use a WiFi connection...
Old Jul 11, 2006 | 06:40 AM
donour's Avatar
More specifically, it needs a USB host controller. Just having usb port isn't enough, you have to be able to host the bus. I ran into the same problem when trying to write a scantool for the PSP.
d
Old Jul 11, 2006 | 07:12 AM
chrisw's Avatar
I checked into it, the FDI drivers supposedly have a winCE version that should work. WindowsMobile is not specifically listed which may or may not be a problem.
