Air temp in Evoscan
Old Jul 14, 2006 | 07:17 AM
Evil_1's Avatar
Air temp in Evoscan
Is this the actual air temp reading in the charge pipe? If so, what are you guys getting for readings when you do a WOT? On stock intercooler or aftermarket?
Old Jul 14, 2006 | 07:22 AM
MalibuJack's Avatar
I think this was answered before.. Its the Intake Air Temp.. At the MAF before it goes through the whole intake tract...
Old Jul 14, 2006 | 07:23 AM
MalibuJack's Avatar
I did discover after logging data that the area our air filter is located in is a location that gets very little fresh air flow..
I ran with and without the scoop ducting air to the location (the plastic scoop from the stock intake) and the temps were 10 degrees cooler (more in some cases)
Old Jul 14, 2006 | 07:28 AM
Wheelhaus's Avatar
you mean 10° cooler with the ram-air scoop? I'd absolutely believe that, but not the other way around without the scoop...
Old Jul 14, 2006 | 07:45 AM
AlwaysinBoost's Avatar
try running it with the scoop but w/o the airbox lid.
Old Jul 14, 2006 | 08:45 AM
MalibuJack's Avatar
Yep, thats what I had intended to write..
But it was just the scoop, no airbox otherwise (I have a 4" intake and 5x10" cylindrical filter)
Old Jul 14, 2006 | 10:40 AM
Kings Fan's Avatar
Has anyone tried running the same test but with a cone intake vs stock airbox? Should be interesting to see which one gets more cool air and put the end of the intake pulling in hot air debate once and for all
Old Jul 14, 2006 | 11:16 AM
MalibuJack's Avatar
once your moving I doubt it makes much difference.. It happens to be a dead area under the hood where there would be no cool airflow without that scoop left in place..
Old Jul 14, 2006 | 12:20 PM
dudical26's Avatar
I wonder what the temps were with you old cone filter in the stock box setup.
Your setup inspired me and I am planning to do the same thing...actually tonight when I install my intake. I will log and see what temps I get.
Old Jul 14, 2006 | 01:07 PM
MalibuJack's Avatar
I hacked mine to pieces not too long ago..
Old Jul 14, 2006 | 03:52 PM
Kings Fan's Avatar
Well that's what I'm saying... it'll prove once and for all with some data... shouldn't be that hard to do either, just a simple before and after.
