EvoScan, Evo's, And Knock
Old Jul 19, 2006 | 06:41 PM
dudical26's Avatar
So after using EvoScan and logging a couple Evo's I have found some odd stuff. I cant figure out if it is just the way that Evo's run or if it is EvoScan. I have logged a stock Evo 8 and a Stock Evo 9 and EvoScan says that both of them are getting multiple counts of knock. This seemed odd so I tried two different gas stations and the results were the same.
I then put an Intake and a MBC on my IX including an Eflash.
I got knock no matter what I did, including run a combination of stock map or the Eflash and 14, 17,and 19 PSI.
My friends Evo 8 also has an intake and a MBC and also a test pipe. His car got a bunch of knock at 20.5 PSI. Then we lowerd the PSI and it got slightly less knock. We also put the boost up to 22PSI and got almost NO knock. However, even without seeing any knock the ECU pulled timing untill the timing was -2 in some places.
So I guess my question is this, has any one used EvoScan and not gotten knock. If you dont use Evoscan what do you use to log knock and does your evo always get knock(is it modded)
Is it me or is their something odd going on when two stock cars both get knock even when running only 17 PSI.
It has been very hot around Jersey latley. However tonight we did the evo 8 logging and it was 78 degrees with 54% humidity.
Old Jul 19, 2006 | 07:03 PM
Second Chance's Avatar
I have a stock ix justed tuned by me and i have no knock. I do have a torque dampener engine mount that may help with any false knock.
Old Jul 19, 2006 | 07:09 PM
andenbre's Avatar
I have had logs with no knock whatsoever for 3rd gear pulls and some that had a knock count of 1-2. this is with a stock evo9. this was also on 93 octane bp amoco ultimate.
Old Jul 19, 2006 | 07:29 PM
stingerbtry's Avatar
Same here but with worthless cali 91 octane.
Old Jul 19, 2006 | 07:55 PM
Ludikraut's Avatar
How did you arrive at the conclusion that you were getting pulled timing with no knock counts? IIRC, the stock IX high octane timing map does have areas in it with -2 degrees of timing. Care to post the log files? I'd be interested in seeing them.
On my car I generally do not get any knock once I clear 4000 RPM. Unfortunately the ECU does report knock counts below that fairly consistently, which is most likely due to the balance shafts having been removed from the block or possibly some of the other mods on the car.
l8r)
Old Jul 19, 2006 | 09:59 PM
C6C6CH3vo's Avatar
For the ECU, knock can be the following and may pull timing in response:
1) Detonation
2) Potholes
3) A chopper in next lane
4) A Dwn pipe hitting crossbar
Old Jul 19, 2006 | 10:09 PM
taenaive's Avatar
I have seen 0 knocks on my car and I have seen as many as 10 knock counts also (when I did aggressive tune and boosting high). It all depends on the tune and condition I think.
I found knocks even at partial throttle around 3000 rpm at 90 to 120 load range. So,Yes knock can happen even if you are boosting at 1 psi. And, hot weather gives me more knock counts.
I think evoscan knock sum count is somewhat accurate. I wouldn't ignore it.
Old Jul 20, 2006 | 05:16 AM
dudical26's Avatar
1) Detonation
2) Potholes
There were no potholes
There was no one else on the road
I have stock DP so it is not hitting anything.
Old Jul 20, 2006 | 05:17 AM
dudical26's Avatar
What kind of gas?
Other then engine dampener, what mods do you have
what did you adjust when tuning
Did you have knock before you tuned it at all?
Old Jul 20, 2006 | 05:19 AM
dudical26's Avatar
l8r)
I am at work now, when I get home I will post up some of the logs that I have.
Old Jul 20, 2006 | 05:39 AM
jcsbanks's Avatar
I'm fairly relaxed about the log behaviour because I have listened to the engine with my own ears (through det cans) and know that it doesn't knock except occasionally on lift off (most of which I've also sorted) and it performs very well. I get sporadic low grade counts of 1s which I think are meaningless. 2s and 3s show I'm running it a bit "sparklier" as I call it. When I've seen a 4 occasionally (especially as a spike) on logs I have also found that there has been detonation and the timing seems to get pulled, but I then tune this out.
So I'm "cooperating" with the OEM knock control system and it seems to work. Knock is a sporadic thing and I'm pleased that the system is there in the background. I'm not getting hung up over a degree or so here and there and generally I find the system behaves appropriately. I'm cooperating because if I put more timing in the ECU seems to pull most of it out again. Even with methanol in the tank (with safe lambda) and no extra timing it will still do the odd 1 or 2 during spool up even with -1 or -2 timing. It hauls hard and doesn't knock so I don't mind.
Significant knock is probably being prevented by the OEM system doing its trimming work. Since there are tables in the ECU that reveal it can pull out substantial spark timing before the next spark, it may be that the brief noises are too short for me to hear even through det cans.
Old Jul 20, 2006 | 06:28 AM
16ggst's Avatar
my car is still stock and i am seeing 1 count of knock in the 3700-4300 range.. but other than that nothing..
Old Jul 20, 2006 | 06:39 AM
gsrboi80's Avatar
^ Yea the most Ive ever seen is 1 count of knock in that range as well
Old Jul 20, 2006 | 08:33 AM
Ludikraut's Avatar
Cool.
l8r)
Old Jul 20, 2006 | 09:19 AM
C6C6CH3vo's Avatar
Were there any choppers near by? JK
Just add a gallon of Xylene or toluene to 5 gal of gas and see if it goes away. If so, then for sure it was knock, if not - ?
