PRESENTING evoscan
Old Jul 26, 2006 | 11:45 PM
trinydex's Avatar
PRESENTING evoscan
can someone do a lil info gig on evoscan? what's great, what's not, what it does, how it works, maybe some screenshots... i'm having a hard to finding anything...
BTW, i just paid to support evoscan!
Old Jul 27, 2006 | 08:47 AM
MalibuJack's Avatar
It works well for a beta program, has some rough edges such as a few calculations are off (which is easily fixed)
Fuel trims do not appear to follow what my regular scantool sees for trims...
Its useless for monitoring fuel trims, their either not updating frequently or they don't represent what I am expecting to see from trims, which is a huge PITA if your tuning for drivability.
Software was supposed to be open source, if I was I'd have already added a bunch of functionality to it.. (TurboXS Tuner Pro log input for EGT, MAP, AFR, etc..)
Old Jul 27, 2006 | 08:58 AM
ScrappyJack's Avatar
Adding to what Malibu said, I mostly use it for logging Knock Sum, Timing Advance, TPS, and RPM. Combined with the logging from my FJO setup (RPM, AFR, Boost), it makes for a pretty complete (if sometimes awkward) package.
Hopefully the final release will be more accurate and have more features, including integration of more widebands.
EvoScan homepage including a screenshot and more info.
Old Jul 27, 2006 | 01:18 PM
trinydex's Avatar
so you're basically sayin' it's not the complete logging deal right? what if you use it in conjunction wtih zeitronix... should be aite right?
Old Jul 27, 2006 | 02:11 PM
bhcevo's Avatar
Yeah, triny, I use it with zeitronix and run both logging programs simultaneously on the same laptop. You just have to consult a different log to get your AFRs.
Future evoscan releases should incoporate zeitronix AFR input.
