A great tune with EcuFlash (by EIP Racing)
Old Aug 10, 2006 | 01:31 PM
UCB's Avatar
UCB
Originally Posted by KOEvo
Based on the calibration of this specific dyno it is actually only 10-15 whp less then a dynojet dyno. So we are looking at just over 300 dynojet, which is about right for a IX.
Not really. The EIP dyno, gruppe-s, and vishnu dynos all put down similar numbers. 300whp on any of them on 91 is BIG. 330-340 on a dyno jet
Stock IXs throw down 230-235 on the EIP and GS dynos, his is obviously a high flier at 245. The highest i have seen on the GS is 241 (wilson1s MR)
Old Aug 10, 2006 | 01:32 PM
onefast4dr's Avatar
nice numbers ... but isn't 23 psi a little too much boost without a TBE? I guess if 23 psi is just a spike you should be fine, but if you have the mbc set at 23 that probably too high. but anyways thats a good tune especially if you have 0 knocks.
Old Aug 10, 2006 | 01:45 PM
UCB's Avatar
UCB
and yeah, it would be great i fyou could post this on NCE. Seems like the SCE/NCE server got hacked
Old Aug 10, 2006 | 01:54 PM
wzcx's Avatar
Originally Posted by stingerbtry
How much did it run you for the flash and tune?
I paid $550- and I think I got my money's worth. I am certainly happy with the power, and I learned a lot. Paul was quite patient, explained a lot of tuning principles, has a cute dog, and was very careful with the car. :)
Well, yes. I agree with you in general. But with EGTs not abnormally high, a fair amount of taper (23@4000, 22.5@5000, 22.5@5900, 20@6000, 18.2@7300), and careful monitoring of knock and AFR, I think I'm pretty safe. I recognize the potential for problems with blowing a head gasket, the turbo's seals, etc., but I have faith in Mitsu's sturdy little engine. EDIT: there are a lot of folks running harder than I am on essentially the same motor.
Old Aug 10, 2006 | 01:55 PM
ST's Avatar
ST
BASE TUNED
WTQ 220.9 @4000 293.8 @4250
WHP 245.9 @6500 290.2 @6000
Wow - those are nice numbers just for an essentially stock tune O.o
You must have a strong ix!
webguy330i's Avatar
Originally Posted by wzcx
Yes sir! And it was farking hot. We went through a whole tank on the dyno- I had to keep an eye on Paul so he didn't turn on the AC while sitting in my car on the dyno.
That's probably a good thing to keep knock down to nill when it's that hot again out on the road. It was a scorcher that's for sure.
Boltz.'s Avatar
FCOTM Winner
^ a TBE won't allow you to safely boost more. running 23psi and using a stock exhaust have nothing to do with eachother
Old Aug 10, 2006 | 02:00 PM
ST's Avatar
ST
when you get a chance please post the dyno graph...
its interesting you're seeing as much hp as torque, something contrary to what I typically see on moded evos (usually 20lb torque more).
i wish the MDynos had avg torque / hp readouts like the Dynojets do...
Old Aug 10, 2006 | 02:02 PM
webguy330i's Avatar
You sure? I would think the stock exhaust bottleneck + flowing more exhaust gas + leaner mixture = higher manifold temps = higher heat soak = more prone to knock/warping/failure in general...
Old Aug 10, 2006 | 02:05 PM
RazorLab's Avatar
They do.
Btw, usually the Trq falls off below HP the more power the car gets with 4G63T's.
Old Aug 10, 2006 | 02:06 PM
RazorLab's Avatar
And you would be correct.
Old Aug 10, 2006 | 02:08 PM
fastrob691's Avatar
actually most if not all the mustang dyno's give peak/average/and low numbers. plus peak boost, etc.
wzcx's Avatar
Thank you both- I will keep an eye on things. Perhaps now that I've started modding, my life is over.
Old Aug 10, 2006 | 02:13 PM
webguy330i's Avatar
Well hells bells jim.
4-BNGR's Avatar
EIP posted an ad for EcuFlash tuning on NorCalEvo, and I took them up on it- I spent all day yesterday (12 hrs, approx 60 runs) on the dyno. Before and after:
HTML Code:
        BASE           TUNED
More stats:
Mustang Dyno, Air temp 101.5F, Evo 9 MR, 06
Mods: MBC.
I'll post graphs after I'm home and near a scanner.
Thank you Paul @ EIP, and his guys who bought me lunch! (I wish NCE weren't down right now.)
Seems like your car was a "dog" from the factory.
