A great tune with EcuFlash (by EIP Racing)
this results are really surprising to me because the EIP Mustang reads very conservatively. I'm stunned that you achieved this on the stock exhaust. The numbers would seem perfect if you had a full turboback, but since you're using the stock system I dont know where Paul found that other 30whp. Most IX's hit around 270whp on a MD or DD with just a tune/mbc. Yours must be super strong I guess? Hmmm
Originally Posted by razorlab
They do.
Btw, usually the Trq falls off below HP the more power the car gets with 4G63T's.
apex- agreed on your point, but what i was saying is his torque is about 20 ft/lb short of typical moded ix numbers, hence i would like to see the avg. numbers , dyno graph itself.
Originally Posted by Ultimateone
Insane..but did you pay for a 12 hour tune?
Originally Posted by ST
I need to get paul to get me another printout. max hp/tq readings don't necessary tell the whole tale, because as they say its the area below the curve that matters.
http://www.norcalmotorsports.org/use...ynochart02.jpg
As far as peak trq numbers. It really varies car to car, tune to tune and setup to setup. Stock turbos spool fast so the peak boost is in the motors torque efficiency range. Some tuners like to put more timing in the peak torque range then others which creates more torque. Some run bigger boost. It really depends.
Yes, the normal dyno printout that EIP gives doesn't have the max/average/low readings . The test report with trace lines and AFR do, like this:
uh huh..
anyhow...as i said, i'd like to see the avg hp and tq, since that will tell the real tale...
so you're saying his car has problems, since his is 20lbs short of typical modded ix's? or are you saying that tbe mods add 20lbs torq? or maybe that he has a one off rare ix with hi hp #'s? what are you saying...(besides rambling)?
I was basically telling you why some 4G63's have higher torque, or lower torque, or the same torque as HP. I wasn't projecting anything like you are. How long have you been around 4G63's? How long have you been tuning them? Have you tuned them at all?
Originally Posted by webguy330i
You sure? I would think the stock exhaust bottleneck + flowing more exhaust gas + leaner mixture = higher manifold temps = higher heat soak = more prone to knock/warping/failure in general...
What the hell is your problem ST? When did I say anything like that?
4g63's, but when someone is just blathering stuff left and right without a point, it just sort of convolutes the issue in general.
cliff notes for you: you have great background, no doubt....why not put a summary on what you think?
my point was simple: peak torq / hp numbers don't mean much, avg. means more and that his pk tq was a little lower than modded ones (maybe thats the main benefit of tbe?)....i don't need to know pound my chest about 4g63's to make those simple derivations, but hey this is the intarweb isn't it?
It looks normal to me with his mods. You're the one tripping. I give you info and you think I'm attacking you.
Just because I told you that I thought you where a little cry baby about the rust on norcalevo, doesn't mean you have to be butt hurt about it on this board. Get over it.
anyhow, for someone so perceptive, i'm surprised you didnt the least mention about avg hp / tq .... i'm as curious as anybody and do value your (somewhat convaluted) response, especially being all 4g63 knowledgable and all! Give us more than some ambiguous safe response man!
Okey dokey kids, quit it.
My other plot says, for averages, 58hp, 119tq. Quite a bit below razorlabs, but then he's making more than 20 hp more peak as well. I certainly think there's room for improvement on my tune- but it's quite a good start... Maybe when you all see my graphs you'll start laughing about it being a dyno queen. I would like to see the tq hold on a little longer up top.
