load flopping.... need some input
Old Aug 14, 2006 | 01:14 PM
AlwaysinBoost's Avatar
you NEED a wideband gauge to tune your A/F ratio.
Old Aug 14, 2006 | 01:18 PM
-=SPECTRE=-'s Avatar
Yes, I know that - but how can you use your AFR to determine what load cell you're in when your actual AFR has nothing to do with the AFR numbers in the ECUFlash tables? It's been said many times that they never correspond with real AFR numbers usually being much leaner than target AFRs in ECUFlash. Therefore you can't use AFR to determine what load cell you're in since they don't match.
Old Aug 14, 2006 | 01:21 PM
Atlmethevo's Avatar
It's called using a dyno and matching up the map with the dyno plot. Hop on a DD and you can tune 100 rpms at a time
Old Aug 14, 2006 | 01:23 PM
So your assertion is that you cannot reliably determine what load cell you're in without 100 RPM incremental tuning on a DD dyno?
Old Aug 14, 2006 | 01:31 PM
AutoXer's Avatar
Originally Posted by -=SPECTRE=-
How can you use AFR when your actual AFR rarely if ever corresponds with the AFR you set in ECUFlash?
I didn't say actual AFR, I said target AFR. EvoScan can log the fuel value that the ECU is asking for. It's actually just a byte value. 128 should roughly be equivilent to 14.7 to 1 AFR with a totally stock engine... but that doesn't matter. All you care about is what the ECU is asking for. It seems to work fairly well, but the value and its location(0x32) was sort of stumbled across.
I'm confused as to how this is confusing. In open loop mode the ECU simply pulls a value from a table to know how much fuel to use. 0x32 seems to be that value. Simply look up the load from the fuel table by crossing the RPM and this value.
Still lost?
Atlmethevo's Avatar
I can change the cell on the dyno and hold that load and see what cell the car is in as well as timing / boost / AF / and all the temps. You live in GA come up to Dyno4Mance this Saturday and you can see it for yourself.
Old Aug 14, 2006 | 01:32 PM
Atlmethevo's Avatar
Some people dont have a clue and these people will be the 1st to blow it up. Give someone a long enough cable and they will hang themselves lol
Still lost?
Old Aug 14, 2006 | 01:35 PM
Listen, Chubby. Don't get mad at me because I called you out on your own assertion about 100 RPM incremental tuning. At least I'm smart enough to ask questions rather than to go around randomly bashing vendors.
Old Aug 14, 2006 | 01:39 PM
Atlmethevo's Avatar
Well then learn what you are doing then. Don't you have a dynoflash already? Pull the damn map, look at a stock map, look at the changes and LOG it not too hard.
Old Aug 14, 2006 | 01:42 PM
I don't have a Dynoflash, my car is stock other than having made some adjustments on my own based on what I've learned so far. I'm at the point now where I need to know what load cell I'm in and from what I've read on here and elsewhere is that it's basically one big guessing game.
Old Aug 14, 2006 | 01:44 PM
no that is wrong. you log your TIMING number in EVOScan and then find that on your timing map. Then you can see based on what RPM/Load timing cell your in where your falling with regard to your A/F.
I hope that makes sense... if not do a search for a thread I made about this subject.
Old Aug 14, 2006 | 01:49 PM
Atlmethevo's Avatar
It's not a guessing game if you have the right tools, aka Logger, dyno etc. The better the tools the better the data the easier to tune it's that simple. Ever try to build a house with a flat head screw driver? Well that's where you are at right now with tuning the evo. At least get a logger of some sort, best bet would be a dyno because you can see the changes right after on a graph and also see if it's pulling timing on the fly.
Old Aug 14, 2006 | 02:10 PM
Still lost?
Ok now that makes a lot more sense - Does this value need to be manually added in Evoscan? Looking in there I don't see anything jumping out at me as being for AFR other than logging a wideband.
Old Aug 14, 2006 | 02:21 PM
Mad_SB's Avatar
Originally Posted by honki24
I've got a question:
can someone post up a concurrent screenshot of a pull showing evoscan's knocksum output and ecu+'s knock voltage synced up "side by side"?
I don't have the evoscan software and don't know if it's worth it to see "real" knock. Also, does anyone know that the evoscan software is most definately reading knock as the ecu sees it? Does the ecu really see it in "counts" or is that just a more convenient way for us to interpret it? My motor is almost always in the 1.2 volt range even cruising, I have cams, etc. It's always been a grey area in deciding where real knock is w/ the voltage. My guess thus far has been to keep voltage under 1.85V (except for lift of course). I think a comparison of knock sum and voltage would help greatly.
I would, but ecu+ palm will not log with the OBD-II switch flipped so you can connect evoscan. I will try and log both with my laptop this weekend, but not sure how well that will work with ecu+ crashing if it looses focus, plus my craptop is a slow P3.
nj1266
Jan 25, 2026 01:43 AM
blk-majik
23
Aug 16, 2012 04:20 PM
killerpenguin21
Apr 12, 2011 01:07 PM
eag36
Mar 29, 2010 01:32 AM
Mad_SB
Jul 13, 2006 05:18 PM
