Wideband tuning question
Old Aug 13, 2006 | 06:43 PM
RedV's Avatar
Well I think I'm done tinkering around with EcuFlash on my own and would like to do it properly and tune with a wideband. However, right now my car is bone stock and will probably stay that way until at least next year.
I have a friend who has a wideband, however since my exhaust is obviously stock I don't really want to bother with taking out the stock O2 sensors. Which brings me to my question; Is there any way to mount a wideband O2 in the exhaust temporarily for tuning? Would this even do any good if it were behind the cat and at the exhaust tip?
I've heard that when Al does a tune he is somehow able to temporarily mount an O2 on the customer's car for tuning. Is this something that can be rigged up somehow?
My other option is of course to do the E-Flash thing with Al, but I've heard that he's pretty busy right now so I thought I'd try and find out a little info on this first.
Thanks
Old Aug 13, 2006 | 07:47 PM
TTP Engineering's Avatar
Some use tailpipe clamps. I would just remove the rear O2 sensor and insert the wideband in that bung for your tuning session.
Old Aug 13, 2006 | 08:03 PM
Atlmethevo's Avatar
That will cause a check engine light but I guess you could.
Old Aug 13, 2006 | 08:06 PM
So will installing a Tilton. What is your point?
You have about a 15% chance of throwing P0420, big whoop.
Old Aug 13, 2006 | 08:13 PM
ShiftySVT's Avatar
Doesn't the cat through off the AFT reading?
Atlmethevo's Avatar
So having a check engine light is what is expected if I were to take my car to your shop?
Old Aug 13, 2006 | 08:34 PM
MalibuJack's Avatar
It doesnt affect it as much as you think.. A cat is only effective at idle and very low load cruise, at WOT and high loads it doesnt affect the AFR's much..
Old Aug 13, 2006 | 08:37 PM
I have validated Jacks claims. In fact I was surprised to find this out.
Old Aug 13, 2006 | 09:31 PM
l2r99gst's Avatar
In my Eclipse, I ran my wideband in the rear O2 sensor bung, with a high flow cat and with a test pipe.
The readings with the cat were just about identical to the readings with the test pipe. The only difference was that the cat would smooth out the reading a bit, where the display wouldn't jump around as much.
Eric
Old Aug 13, 2006 | 10:30 PM
elhalisf's Avatar
ya, just remove the rear O2 sensor and unplug it.
if you need help with wideband tunning, give me a call. i have used the zeitronix wideband with the ecuflash to tune my car.
Old Aug 13, 2006 | 10:35 PM
elhalisf's Avatar
double post
Old Aug 14, 2006 | 08:01 AM
-=SPECTRE=-'s Avatar
Since you're running stock exhaust and plan on eventually upgrading - You can just remove the second O2 sensor to tune with temporarily and put it back when you're done. Easy enough to clear the code if one comes up.
Or if you have an aftermarket exhaust get a shop to weld in a second bung for a wideband O2 sensor. It's a cheap, easy and permanent solution.
