MIVEC voltage?
Old Aug 20, 2006 | 09:53 PM
JohnBradley's Avatar
MIVEC voltage?
This is kind of out there but I wonder if anyone knows or has taken the time to see what voltage range the MIVEC solenoid operates on. I would assume that 0* on the map is 0v, but what is full advance? 5v maybe?
Old Aug 20, 2006 | 10:49 PM
andenbre's Avatar
I would think that it is a pulse width signal with 0 = off and either 5v or 12v on
Old Aug 20, 2006 | 11:20 PM
Well for what I am thinking it doesnt matter what the voltage is for any voltage between 0* and 30*, I am just curious if its 5 or 12 when its at full (30*). I surmised it would be one or the other. Thanks for the help though. It seems I need to do some R&D.
Old Aug 21, 2006 | 01:53 AM
jcsbanks's Avatar
It is I believe a closed loop oil control system. So an operating condition of the solenoid valve (if that is what it is) will not tell you the state of cam advance.
Old Aug 21, 2006 | 11:11 AM
Actually I am not after cam advance. There is a second load/rpm indexed map going to waste that can be used for an additional control. I am thinking that it can be used to run meth or nitrous. I am studying the pinout as we speak, but I was curious what the voltage is at full advance for running the triggers in other systems.
Old Aug 21, 2006 | 11:12 AM
Tuned by LIM's Avatar
absolutely right
solenoid have 2 pins out, one connect to 12V and another one connect to ECU
if you want to view cam angle, you need to compare phase between crank position sensor and intake cam position sensor.
by the way if solenoid duty = 0% cam timing will fully retard (0deg advance)
solenoid duty = 100% cam timing will fully advance xxdeg advance (except low RPM because oil pressure not enough to push cam pulley)
Old Aug 21, 2006 | 11:14 AM
So it is 12v then?
Old Aug 21, 2006 | 12:05 PM
High_PSI's Avatar
12.41 @ 109.1 / 12.62 @ 111.8 / best 60' 1.707
englishracing.net
What are your mods with these runs?
Old Aug 21, 2006 | 03:34 PM
englishracing.net
My flash, TurboXS TBE with test pipe, drop in, and AVgas. Oh and 28psi with a UICP that was to blow off later that night (thought I checked everything in my car prep). I also removed the clutch restrictor which took some getting used to. The 12.62 was also ran with a 2.1 60' so there is alot more in the car. My 275's werent helping my launch any either. Someone in our group ran a 12.20 @ 113.35 that night with everything that I have but stock tires. Those stats will improve after wednesday night I promise.
Old Aug 21, 2006 | 07:14 PM
High_PSI's Avatar
Yeah they should, Ix's seem to be that fast on pump gas and now special mods.
Raceghost
Jun 21, 2016 12:40 PM
fireroasted
18
Nov 2, 2015 06:37 AM
jmoudry
20
Dec 31, 2006 08:01 AM
GOKOU
Mar 9, 2005 08:19 AM
twardnw
11
Jan 20, 2005 06:34 AM
