EVOScan MAP Sensor Voltage formula???
Old Jun 9, 2016 | 01:28 PM
Raceghost's Avatar
Does anyone have the EVOScan MAP Sensor Voltage formula or dataitem list? I know and have the one for calculating PSI from request 38 I think. Is there a formula for logging the same request or getting it in volts. Presumably it would be a 0-5v scale. This would be awesome for keeping an eye on voltage the MAP sensor is receiving or putting out, to know if a sensor is going bad.
Thanks in advance.
Old Jun 9, 2016 | 08:53 PM
Raceghost's Avatar
Bump.
Old Jun 10, 2016 | 01:11 AM
Raceghost's Avatar
Bump.
Old Jun 12, 2016 | 03:03 AM
WytWun's Avatar
A general formula for a 0-5V ADC input value as volts (to the nearest 0.02V) would be
x * 0.019531 + 0.009766
however for readings to the nearest 0.1V
x * 0.019607
should suffice.
Old Jun 21, 2016 | 12:40 PM
Raceghost's Avatar
Thank you. Seems to work fine.
TJung
Dec 30, 2009 01:43 AM
Evo8uk
Sep 15, 2009 02:18 PM
tephra
Feb 11, 2008 09:09 PM
nj1266
Jul 25, 2007 08:15 PM
