Evoscan formula for GM 3 bar MAP
Hey Guys,
Does anyone have an accurate formula for EvoScan?
Currently I have "0.175934*x - 14.5"
Any other GM 3bars confirm?
Cheers
D.
Cheers
D.
no replies
I have a closer number 0.17573 - I think its correct, from the manual:
240kPa is 3.884volts
THUS:
(3.884/5)*255 = 198.084
198.084 * 0.17573 = 34.80930132psi
In Google:
240 kilopascals in psi = 34.8090571psi.
This also works for my zero-psi reading ie:
evoscan logs 82 as engine off pressure
82 * 0.17573 = 14.40986psi
Which is about correct for my altitude (300ft above sea level)
THUS:
In Google:
hrmm so the only thing that is bugging me is that my bone stock IX seems to be getting good boost:
http://img527.imageshack.us/img527/1...3barmaplu9.png
as opposed to my old car:
http://img299.imageshack.us/my.php?image=dynoxd0.png
I have the voltage listing for the JDM MAP and a GM 3 bar somewhere but I will have to look for them. Sorry I didnt see this earlier and I cant believe no one else jumped in...geesh guys. I will send it to as soon as I find it Dave.
To be clear you are just looking for the pressure to voltage conversion or the scaling for the ECU MAP check?
Here is the quick teaser:
http://hhscott.com/93tmv/3-bar_map.htm
I will see if I cant find all my hard copy paper research tonight. I have it all written out when I was trying to figure out stock ECU speed density with a different MAP sensor, but I am not sure where I put it after I abandoned that project.
Thanks John,
Yah basically, I have the gm3port spec.pdf that is floating around, unforunatley below 70kpa and above 240kpa the relationship between volts and pressure changes.
But that's ok because I don't plan on doing anything on the above two conditions.
I am pretty sure I have the "conversion" (volts to pressure) formula correct now, but wanted to bounce it off other ppl
Cheers
D.
Cheers
D.
Now that I thoroughly reread the post and looked at the pix, I would set the correction value to what it should be assuming perfect sea level. I would then adjust the stationary pressure value to compensate for any altitude. I apologise for being a little obtuse earlier.
