Dynoed My 05 Evo 8
Old Aug 22, 2006 | 02:25 PM
HKSevolutionNYC's Avatar
Dynoed My 05 Evo 8
will have the dyno chart up 2nite.
2005 EVO 8
3" TBE
ARC Intake
Walbro Fuel Pump
21PSI with Turbo XS HP MBC
Mail in Flash from DYNO FLASH
after flash car did 285 HP from stock
did a mild tune on it with good AFR and got 311 HP and 346 TQ out of it with minor adjustments. still a little rich cause it was hot outside.
Old Aug 22, 2006 | 03:19 PM
JohnBradley's Avatar
Did you ever have a baseline to go by? I am curious how much a gain there was from stock to Dynoflash. 26whp over that is great.
Old Aug 22, 2006 | 07:40 PM
gogoevo's Avatar
what kind of dyno??
Old Aug 22, 2006 | 09:13 PM
yes from stock to ecu flash was 285 HP and then i got tuned and made 311 HP
Old Aug 22, 2006 | 09:34 PM
Rnm's Avatar
Rnm
Impressive numbers, especially your torque.
Old Aug 22, 2006 | 09:50 PM
ray3328's Avatar
That's alot of TQ. Was this on 93 octane?
Old Aug 22, 2006 | 09:54 PM
SlowCar's Avatar
what kind of timing and AFRs are you running?
Old Aug 23, 2006 | 10:06 AM
Originally Posted by gogoevo
what kind of dyno??
this was on a dyno dynamics dynamometer
Old Aug 23, 2006 | 10:07 AM
yes this is on 93 octane, i use that fuel only
Old Aug 23, 2006 | 10:08 AM
sorry i couldnt get charts up 2day. will try again 2nite at my job.
Old Aug 23, 2006 | 10:10 AM
gregfromblur's Avatar
dammit!! cali gas sucks!!!! Good TQ numbers
Old Aug 24, 2006 | 11:43 AM
nj1266's Avatar
Did you log your timing and Knock Sum? Could you post them so we can see them. I could be wrong, but the torque number you posted suggests an aggressive timing profile. I have an 05 with TBE, filter, and Xede and my hp is close to yours, but you car is putting approx 45-50 ft-lb more torque than mine. The timing on my 91 octane custom map is very tame with little to no KS.
Old Aug 24, 2006 | 09:47 PM
ill see if i can get that, only printouts i got were afr and HP and the other was HP and TQ.
Old Aug 25, 2006 | 03:24 AM
tuning g's Avatar
great numbers
Old Aug 25, 2006 | 09:12 AM
Dyno Dynamics tend to read low like Buschur's Mustang correct?
