I want more PSI??
Old Sep 25, 2006 | 12:26 AM
ant_turbo's Avatar
Question I want more PSI??
MOD'S ARE 3'CATBACK,HKS INTAKE,HKS EVC_4 255 Walbro Dyno Flash Road Tune!!
My question is If I add some bigger injectors will I make more power?? And will I be able to up the boost safely?? O ya on my mail in flash I made 301hp,,,,,And I dont know if I nade any more power with the road tune,,I didn't go back to the dyno,,
Thanks,,,,,,
Old Sep 25, 2006 | 02:29 AM
Dapper Dan's Avatar
Thanks,,,,,,
im pretty sure the stock injectors are good for somewhere around 380 whp........so......no you wont gain any more power from getting injectors...why dont you get a downpipe and testpipe since all you have is a catback?
Old Sep 25, 2006 | 02:52 AM
smoothmarine187's Avatar
Veteran: Marine Corp
I'm not sure how much boost you are running now, but you probably can't go to much higher since you are running on that crap 91 octane gas. You should buy a downpipe, and then if you want to run alot more boost, you should look into alcohol injection.
Old Sep 25, 2006 | 07:39 AM
mrfred's Avatar
Larger injectors only make more power if your injectors are maxed out which I doubt is happening because lots of people are running TBEs and cone filters on IXs without issue. I suggest a DP and HFC, and then you may be able to increase the boost without additional knock.
Old Sep 25, 2006 | 07:50 AM
Malick67's Avatar
http://www.buschurracing.com/evo9-stage0.htm
Here is a good start for you.
Alcohol injection is great also.
Old Sep 25, 2006 | 11:34 AM
ant_turbo's Avatar
I made that 301hp @20.81 psi on pump 91 on a DYNOJET
But I have seen people dyno with a downpipe and catdelete Boost Controller on 91 pump and they didn't really make more power then 306hp..
THANKS FOR THE INFO,,,,
