Quick way to calculate actual AFR
Originally Posted by Ackerson
Jack, maybe you could take a look at the Dsmlink source code and see what they used for a formula for the A/F estimate. It seems to be very accurate.
A lot of people used that in correlation with their WB readings to find out when there was a fueling or air metering issue, because the two would start to diverge or be off altogether.
EDIT: I just looked at the source code and it does what I mentioned. It uses more data, such as the specific gravity of the fuel and deadtime, too, but it basically just does what I mentioned above.
Eric
Can you express it in a useful formula? Its possible that data is already available to calculate from, but I suspect without a unclipped MAF value it might not work too well..
willdatrill2007
Oct 9, 2016 09:01 PM
