2nd o2 Sensor?
Old Sep 28, 2006 | 11:05 AM
MalibuJack's Avatar
Yep.. thats it..
Old Sep 28, 2006 | 11:10 AM
SophieSleeps's Avatar
So if someone could just help out with a complete evo IX pinout...it really would be that simple.
Old Sep 28, 2006 | 04:43 PM
evo ippo's Avatar
Originally Posted by fromWRXtoEVO
Evoippo,
You can try fliping the test pipe 180 degrees so that the 02 senor faces in a different direction.
Only when you use the stock cat you run out of room but then why to use a stock cat if you are planning on putting a CEL fix right?
I ran all 3 different possible configurations on my Evo 9 and never had any isues:
1) 3" HF cat
2) 3" test pipe
3) 3" resonator
What type of pipe are yu running? what type of o2 fooler are you using? they aren't that tall..
Carlos
i am running a helix test pipe and before i ran the dc downpipe but the o2 went on my hks carbon ti exhaust
Old Sep 28, 2006 | 04:44 PM
evo ippo's Avatar
+1
then a complete right out
Old Sep 29, 2006 | 03:24 PM
Originally Posted by evo ippo
+1
1st things first.
Need a diagram.
Old Sep 30, 2006 | 03:35 PM
I figured it out.
Unfortunately I think I may have damaged the heater circuit of my primary 02 sensor in the process.
Never resistance test an 02 sensor wires with the 02 sensor plugged in. Multimeters put out a voltage in order to resistance test and I guess that was too high for the 02 sensor to take. But at least I found the wire.
Anyone have an extra bank 1 sensor 1?
I will post a tutorial in a bit once I have confirmed that it works.
The posted EVO IX pinout is missing wires.
Old Oct 7, 2006 | 09:34 AM
TycoRacing702's Avatar
do a write up on it in how to and post pictures yo.. because i think alot of poeple would really appreciate it.
Old Oct 7, 2006 | 01:59 PM
I thought I had fingered it out, but apparently not.
Haven't had the time to do much more. I will though.
Old Oct 7, 2006 | 02:35 PM
JoeBee's Avatar
I figured it out.
Hm, i am not sure, but I think that the power a multimeter can supply, will not be enough, to damage a heater circuit. I thing this circuit is very durable.
On the other hand, I think the O2 signal outgoing circuit is very sensible to incoming power.
Old Oct 7, 2006 | 06:51 PM
You're on the money.
I had traced the heater wire with a multimeter's resistance test. I found the correct wires on the ECU. After I cut one, and connected it to the other, I got a heater code for low voltage in B1S1 which I thought was very strange since that was the "untouched" sensor.
At that point I thought I had damaged the primary sensor using the multimeter. After returning the wiring to stock, I realized I had not done so.
When I get a sec, I will trace the other heater wire. Perhaps I used the wrong one. You wouldn't happen to know which black wire is what do you?
