MitsuLogger V1 Beta 3 to be released tonight!
Old Oct 2, 2006 | 08:57 AM
MalibuJack's Avatar
Okay.. Version 1 Beta 3 is due to be released TONIGHT around midnight..
- Bugfixes to resolve issues with logging speed, you will be able to tune the speed
- Data Logging runs in a seperate thread now, this was done to allow different devices to log data simultaneously and update/read/write the logger at its own rate.
- Support for BEZ_Acceleration (Higher speed faster baud rate logging)
- Support for custom 16 bit (2 byte) Responses (Bez Mods for Load! YES REAL LOAD)
Releases will correlate with new functionality added to modified roms, additionally it will ignore these new values if you have a stock based rom.
New Features Due in this release but will definitely make Beta 4:
- Log File organization and categorization, the log directory can have project folders below it, you can use that to organize your roms and logs according to project (Client) name. (this might not make this release since there are quite a few bug fixes I'm working on)
- Project (Client) name will have associated configuration values so each folder can have different log speed, injector scaling, etc..
- Map Tracing using fixed axis from the client configuration file (no reading from the rom just yet) "Auto-Fill" timing values while driving..
Old Oct 2, 2006 | 09:19 AM
l2r99gst's Avatar
MalibuJack,
One great feature to implement with the map tracing would be to highlight cells where there is knock present. I believe that I saw a screenshot of ECUTek a while back showing that ECUTek does this.
That would make it super simple to see exactly what cells need to be modified for a knock free tune. I believe (just going on memory from that screenshot) that ECUTek colored the cells in shades of red, the darker the red, the more knock occured in that particular cell.
Just a thought.
Eric
Old Oct 2, 2006 | 10:01 AM
jcsbanks's Avatar
I used to like this feature on Ecutek, but it would overwrite if you went over that zone again. The logging on FC Datalogit was nicer still as it would log anything you wanted over the fuel or ignition maps. You could then select mean, min or max for the overlay. Max was useful for knock and for seeing the leanest you were in a zone. Colour coding these would be a bonus on top of that. What neither would do was do this on a log you'd saved and reloaded - only did it live. This was useful for tuning from the passenger seat, but it is nice to go back later too.
Old Oct 2, 2006 | 10:21 AM
cpoevo's Avatar
MJ are you married? I can leave my wife rightnow if you want. I clean and cook but you are on your own when it comes to the sex.
Old Oct 2, 2006 | 10:34 AM
ST's Avatar
ST
This is a great feature I'm looking forward to checking out. Would you be able to elaborate on how you derive at the correct load cells? I'm thinking that you are asking us to fill out a x/y table of our timing maps, and then you do a load calcuated lookup (after filling in the appropriate injector numbers) to match accordingly? How are interpolated timing numbers handled? I know this may be your own IP, so you may not share it, but was just curious!
Thanks again for all your great work!
Old Oct 2, 2006 | 11:17 AM
MalibuJack's Avatar
Map tracing probably won't make it into Beta 3.. Too many issues with getting the 2 byte responses to work right without breaking other things.
However, the knock highlighting will show up.. I'm thinking I will use bonking to show the color more intense if the knock counts increase a counter in the cell.. And it won't "Decay" away. But this complicates it a little so it won't make this version.
The values will eventually get filled from the Rom.. The code to do that isn't quite far enough along.. YOu don't have to fill out anything except the axis data (again, once it can open and read the rom, it won't be necessary) During runtime, when maptracing is working, it will either fill the cells (if left blank) or trace the cells if it was filled from the rom.. Trust me it'll work cool and won't require any extra effort to fill the data.. ITs only a few revisions away.
Old Oct 2, 2006 | 11:18 AM
MalibuJack's Avatar
Yes, I'm married.. However if you cook and clean, my wife would welcome you in..
Old Oct 2, 2006 | 11:21 AM
MalibuJack's Avatar
Oh, and load at idle and low load is done using the 1C value, load at open loop is using the calculated load value, and if you are using "Bez Mods" to get 16 bit load in a modified rom, then it will use Actual 16 bit load.. However this is what complicated the Map tracing and hence why it probably isn't getting into this version.
Old Oct 2, 2006 | 11:22 AM
MalibuJack's Avatar
Code:
LogID,LogEntryDate,LogEntrySeconds,RPM,AccelEnrich,CoolantTemp,Load0,Load2,Load1,ECULoad,InjPulseWidth,AFRMAP,FuelTrim_High,FuelTrim_Low,FuelTrim_Middle,O2FeedbackTrim,O2Sensor,TPS,AirFlow,AirTemp,Baro,ISCSteps,KnockSum,TimingAdv,Battery,EGRTemp,OCTNumber,MDP,Speed,Load
0,2006-10-2,0.00,5593,53.33,-138.89,[00:49:4C],[01:C5:03],[02:C1:CF],112.5,2.82,&h69,17,14,-7,23,4.33,5.49,1522.18,102.44,66.5,195,13,131,8.72,392.5,&h9E,206.25,83.26,67.8332571428571
1,2006-10-2,0.062,2218,82.75,-1106.63,[00:96:FB],[01:E8:39],[02:B1:F9],38.75,34.82,&h1B,24,8,-25,3,0.49,10.20,1276.87,124.16,5.5,75,97,56,17.67,-74.6,&h66,87.5,49.71,3303.796
2,2006-10-2,0.125,1281,64.31,70.81,[00:69:B5],[01:53:A1],[02:34:2F],92.5,5.12,&h74,20,-13,14,-7,1.42,91.76,1012.69,22.50,54.5,24,143,157,17.01,25.3,&h5,172.5,289.56,112.258551724138
3,2006-10-2,0.187,3406,67.45,-15.69,[00:83:76],[01:5A:67],[02:44:0E],38.75,63.74,&hF,-6,-7,-1,-18,2.34,25.49,1006.4,63.29,19.5,239,166,109,7.26,524.8,&hC7,146.25,238.61,10892.1528
4,2006-10-2,0.25,4750,83.14,290.90,[00:35:12],[01:1A:54],[02:20:00],85,42.75,&h8A,16,-22,-16,8,2.24,35.69,239.02,-82.15,118,135,22,173,7.48,281.8,&h7D,65,104.39,793.789434782609
5,2006-10-2,0.312,750,58.82,153.26,[00:EC:18],[01:71:45],[02:DE:BF],43.12,43.78,&h41,-21,-24,-9,14,1.46,23.14,767.38,133.27,43,11,123,32,16.13,192.7,&hC0,295,104.39,1725.92141538462
6,2006-10-2,0.375,4312,7.84,-270.87,[00:68:F4],[01:1D:EB],[02:9E:58],23.75,31.23,&h37,24,-19,-24,-8,2.71,92.16,861.73,91.72,108,210,171,164,18.62,365.5,&h7E,131.25,219.97,1454.43894545455
7,2006-10-2,0.437,1406,41.96,-73.31,[00:CF:89],[01:6D:81],[02:3A:9D],77.5,44.29,&hE2,-7,-10,-11,-18,2.63,21.96,937.21,102.44,111.5,121,48,154,13.93,176.5,&hC7,51.25,254.76,502.181601769912
8,2006-10-2,0.50,1593,95.29,230.40,[00:0F:CA],[01:60:76],[02:1E:1D],27.5,3.07,&hB6,1,3,-15,-2,3.70,74.90,635.29,-1462.64,95,22,161,161,0.22,303.4,&h66,87.5,311.93,42.6579230769231
9,2006-10-2,0.562,6375,69.41,65.84,[00:BB:46],[01:5A:6E],[02:F0:1E],102.5,22.53,&h1A,-16,-22,-4,22,2.69,49.41,1559.92,144.11,48,100,71,108,2.57,244,&hF6,177.5,287.07,2218.40930769231
10,2006-10-2,0.625,5218,43.92,-459.20,[00:10:C0],[01:B2:7E],[02:27:39],51.88,51.2,&hC,0,12,15,-9,4.84,80.39,1081.88,-1462.64,111.5,106,31,223,14.88,119.8,&h66,5,52.20,10934.766
11,2006-10-2,0.687,1281,50.59,73.16,[00:1B:46],[01:A3:D8],[02:7E:2F],142.5,24.32,&h52,13,-15,-3,-14,4.35,60.78,597.55,95.46,109.5,149,237,111,6.16,1,&h42,82.5,55.92,759.390146341463
12,2006-10-2,0.75,2750,0,-667.63,[00:D6:47],[01:B3:67],[02:CE:BD],69.38,4.86,&h68,-9,10,-10,14,0.74,59.22,1528.47,135.60,119.5,29,250,141,11.14,-23.3,&h92,77.5,272.16,118.798961538462
13,2006-10-2,0.812,593,43.53,-741.05,[00:3E:60],[01:65:86],[02:44:94],33.12,5.12,&hE4,-20,7,19,-14,4.72,84.31,704.48,74.11,98,212,97,29,6.08,314.2,&h26,197.5,31.07,57.114
14,2006-10-2,0.875,1625,69.02,-15.69,[00:2E:FC],[01:78:01],[02:6C:49],119.38,58.11,&hD1,-17,-20,-25,-18,1.87,18.43,1566.21,-1062.23,74,185,36,45,0.51,28,&hC7,251.25,104.39,712.638
15,2006-10-2,0.937,3562,55.29,-967.32,[00:8F:33],[01:34:5C],[02:92:57],83.75,27.65,&h92,-23,2,-15,23,4.62,99.22,1346.06,90.81,102.5,252,65,24,12.97,586.9,&h56,220,34.80,485.009876712329
16,2006-10-2,1.00,843,29.02,77.64,[00:8E:4F],[01:4B:CE],[02:4E:5F],63.75,54.78,&h68,11,7,-5,22,3.20,51.37,352.24,50.50,95,116,230,52,12.46,-12.5,&h47,116.25,3.73,1349.99896153846
17,2006-10-2,1.062,2343,98.04,-760.13,[00:94:9A],[01:44:81],[02:CA:DA],14.38,35.33,&h69,-22,-3,9,-1,2.01,94.12,1578.79,47.04,67.5,156,22,27,5.28,586.9,&h26,133.75,172.74,862.006114285714
18,2006-10-2,1.125,4437,78.04,258.17,[00:67:0F],[01:4F:99],[02:84:98],52.5,59.14,&hC4,3,-4,11,-17,0.29,24.31,1213.97,-2269.64,44,174,201,-11,14.81,265.6,&h34,191.25,287.07,773.384142857143
19,2006-10-2,1.187,7531,65.10,296.88,[00:A8:F6],[01:02:F3],[02:12:4A],92.5,52.74,&hA,-23,3,-10,-5,2.54,73.33,723.35,113.08,9,104,146,174,10.78,149.5,&hCD,132.5,252.28,13516.7292
20,2006-10-2,1.25,5718,69.02,-615.51,[00:31:C5],[01:11:3F],[02:F2:D1],34.38,11.78,&h3C,21,-13,-13,10,3.30,77.25,1213.97,117.47,105,183,228,36,6.60,217,&h5A,65,182.68,501.7482
21,2006-10-2,1.312,5000,13.73,234.70,[00:A1:D5],[01:A3:6C],[02:2F:7E],155,50.18,&h61,-1,2,8,-24,3.22,89.80,540.94,191.85,54,196,91,85,13.93,298,&hB7,161.25,54.68,1325.78239175258
22,2006-10-2,1.375,2187,8.63,-2323.71,[00:48:9D],[01:4E:D9],[02:51:CA],27.5,19.46,&h12,-1,-3,4,-24,1.58,13.33,522.07,-247.50,79.5,245,211,121,11.29,468.1,&hE6,101.25,190.14,2766.894
23,2006-10-2,1.437,4750,76.47,-549.84,[00:AF:C1],[01:41:8C],[02:81:90],44.38,27.14,&h59,23,0,4,-2,0.16,37.65,220.15,-0.27,19.5,50,95,4,11.43,114.4,&h70,133.75,105.63,780.935865168539
24,2006-10-2,1.50,5562,21.18,253.21,[00:E1:0B],[01:74:BC],[02:C0:D1],33.12,30.46,&hDD,16,-5,-3,-8,1.23,80.39,868.02,64.27,79.5,22,181,45,1.03,408.7,&hF4,103.75,205.05,353.02756561086
25,2006-10-2,1.562,2875,36.86,106.74,[00:36:36],[01:6B:9D],[02:3D:AE],93.75,39.17,&h14,-23,-18,-13,-6,2.89,28.63,1339.77,-1407.13,67,98,0,43,3.01,154.9,&hFA,98.75,75.81,5018.0121
26,2006-10-2,1.625,7000,12.94,-123.10,[00:9A:9B],[01:B0:D8],[02:18:64],130.62,17.41,&hAD,-6,16,-4,16,1.07,72.94,1440.41,144.11,125,246,222,113,12.09,284.5,&h27,203.75,193.87,257.490416184971
27,2006-10-2,1.687,6781,36.47,243.70,[00:80:0D],[01:5F:73],[02:4B:F6],1.88,42.24,&h9C,1,-24,10,-10,4.88,29.02,584.97,113.08,45,60,151,159,4.98,203.5,&h93,315,294.53,693.812769230769
28,2006-10-2,1.75,1968,80.78,-799.16,[00:67:A0],[01:7D:7F],[02:21:F7],28.12,38.4,&hAD,-20,7,11,13,2.14,8.24,798.83,53.60,7.5,105,30,17,5.86,-82.7,&h9A,87.5,131.73,568.700531791907
29,2006-10-2,1.812,3718,6.27,35.47,[00:6F:F0],[01:45:2C],[02:81:57],81.25,25.86,&h42,-22,6,-7,2,4.37,41.96,949.79,97.41,7,27,37,16,14.15,416.8,&h23,12.5,218.72,1003.33472727273
30,2006-10-2,1.875,6718,51.37,-967.32,[00:FA:85],[01:11:9F],[02:53:46],108.75,26.11,&h62,-15,18,-18,-5,3.02,54.90,1169.94,186.38,41,1,199,215,5.57,443.8,&hF3,60,131.73,682.258591836735
31,2006-10-2,1.937,2875,32.16,-2323.71,[00:93:86],[01:22:E5],[02:07:CA],114.38,15.87,&hF0,-2,11,-6,-14,2.98,54.90,735.93,4.05,97.5,16,40,5,0.95,222.4,&hF4,71.25,109.36,169.148925
32,2006-10-2,2.00,7093,47.84,131.37,[00:D8:11],[01:21:F5],[02:D4:D1],158.75,15.36,&hA9,6,23,-5,-23,4.35,16.08,396.27,36.49,46.5,134,234,119,17.89,73.9,&h67,240,181.44,232.470958579882
33,2006-10-2,2.062,3531,4.31,263.27,[00:5C:6A],[01:5D:A0],[02:2D:6E],24.38,63.23,&h46,-23,15,10,-13,3.92,86.67,1572.5,127.54,59,232,235,107,16.49,206.2,&h6B,260,229.91,2315.34488571429
34,2006-10-2,2.125,7125,15.29,-819.11,[00:A9:E9],[01:D4:C6],[02:C5:78],117.5,36.61,&h29,-10,-2,19,18,1.91,96.47,805.12,-2975.15,56.5,198,78,0,16.42,200.8,&hDB,257.5,242.33,2287.65468292683
35,2006-10-2,2.187,7343,4.71,-1106.63,[00:3A:46],[01:0D:E6],[02:FB:42],85.62,22.27,&h36,-15,-19,5,4,4.25,8.63,320.79,19.20,58.5,72,212,58,18.18,325,&hC9,256.25,191.38,1055.773
36,2006-10-2,2.25,2812,58.43,-352.26,[00:94:0F],[01:D6:0F],[02:26:50],69.38,27.39,&hDA,-23,19,-14,-23,3.86,3.53,213.86,-20.04,33.5,214,53,37,9.46,171.1,&h9A,31.25,298.26,321.76395412844
37,2006-10-2,2.312,3031,34.51,258.17,[00:E2:7D],[01:67:ED],[02:40:8D],6.88,52.99,&h77,2,-7,-18,11,1.09,20.78,515.78,87.30,94.5,30,111,190,10.70,68.5,&h4A,21.25,197.60,1141.24825210084
This is a sample log, as you can see its a little more complex than the original EvoScan log format I was trying to stay somewhat compatible with.. As you can see its still a bit rough, this was done using demo mode at the moment..
Old Oct 2, 2006 | 12:06 PM
RazorLab's Avatar
MJ,
What are the Load0,Load2,Load1,ECULoads?
Old Oct 2, 2006 | 01:11 PM
jcsbanks's Avatar
They are internal RAM references that are used to lookup the fuel and timing maps. Bez Bashni on this thread http://www.aktivematrix.com/forum/vi...t=20&start=150 has found the MUT table which takes logger request IDs and decides which RAM address to output. He has also changed it so that the output is 2 bytes rather than 1 which should be able to give us high resolution logging of load to start with, then RPM and others to give detail and not overflow. The above is the first experimental attempt at logging the REAL load values.
Old Oct 2, 2006 | 01:21 PM
RazorLab's Avatar
awesome work
Old Oct 2, 2006 | 03:31 PM
MalibuJack's Avatar
I had a major problem today, so I won't be releasing anything tonight with the new features for the moment..
Old Oct 2, 2006 | 05:30 PM
MalibuJack's Avatar
I take it back.. I'll have Beta3 out, but none of the new features made it in.. Just the bugfixes and 2byte response support for Bez_Mods...
Old Oct 2, 2006 | 05:41 PM
MalibuJack's Avatar
http://www.aktivematrix.com/forum/viewtopic.php?p=669
Released as promised...
Test it out.. Logger should work right for the most part.. But who knows at this point..
None of the new features made it in, I spent most of the day working out logger bugs and getting 3 byte data (16 bit responses for Bez_Mods)
This logger should fully support logging 16 bit data now..
