HOW TO - Control boost using ECUFLash and the stock boost solenoid
Old Oct 7, 2010 | 07:00 PM
  #271
Ian0611's Avatar
Originally Posted by COL Knock
Why are there four "Max Wastegate Duty" and "Boost Desired Engine Load" maps, do I just use the #1?
What's the Wastegate Solenoid Activation RPM for?
I think most people believe that #1 is the one that is used for WOT but just set all of them to the same thing and you should be fine. I'm using the Tephra v5.10 ROM and I only have one table and it works fine but that's what I did before I switched to the Tephra ROM.
Old Mar 2, 2011 | 05:11 PM
  #272
evolutong's Avatar
sucscribed
Old Jun 9, 2011 | 05:54 AM
  #273
honda-guy's Avatar
i left both stock pill in and just put the new smaller restrictor pill in front of the oem one at the turbo outlet. would it be any different if i remove the stock pill at the turbo outlet?
Old Jul 12, 2011 | 03:32 AM
  #274
honda-guy's Avatar
i'm using #62 hole and i can get boost to hold. it will spike to 24 psi at peak boost and then taper off to 17 psi. i want to hold to 22psi.
it will hold 22 psi with a Perrin or manual boost controller, so there's nothing wrong with the turbo or boost leak.
i have the pill at the T at the turbo outlet. what else can i do to get boost to hold.
Old Sep 26, 2011 | 07:21 PM
  #275
Evo45's Avatar
Nice write up might have to do this to mine
Old Jan 3, 2012 | 02:47 PM
  #276
ViciousLSD's Avatar
Originally Posted by Evo_Kid
On MJ site, somone posted this as a way to control boost. But the pill by the solenoid is bigger, and it need to be smaller to make more boost.
Can someone please confirm this for me? Is that pill's hole bigger that the one near the turbo? Thanks
Old Jan 3, 2012 | 04:03 PM
  #277
Boosted Tuning's Avatar
Dont worry bout pills. Grab a 3port.
Old Jan 4, 2012 | 10:09 AM
  #278
ViciousLSD's Avatar
Just trying to understand and figuring out if my car came out right from the factory
Here's another question
Originally Posted by Mitsiman
Stock System and fundamental basics
The stock system works by running two restrictors, one between the turbo pressure source and the T-Piece which then feeds pressure to both the turbo wastegate and the bleeder valve solenoid. The Solenoid also has the second restrictor on the output side between the solenoid and the air cleaner inlet pipe.
Is the 2nd pill after the solenoid/before the air intake or is it before the solenoid/after the T? Mine's before the solenoid
Old Jan 4, 2012 | 10:13 AM
  #279
There is two pills.
One right before the solenoid. This pill smooths air going into the solenoid. Modifying this pill doesnt do much in regards to increasing/controlling boost. And removing this pill actually makes boost control less consistent.
The second pill is between the turbo and the T. This is the pill that you modify so you can raise and control boost.
And regardless how it came, its best to either A) buy a 3port solenoid if you want to do ECU boost. Or B) buy a MBC.
Old Jan 4, 2012 | 10:14 AM
  #280
wjamyers's Avatar
If you're not sure you're car is right at the most basic level you should find an expert that you trust locally. cross reference what you learn here with what you learn there.
Old Jan 4, 2012 | 10:47 AM
  #281
ViciousLSD's Avatar
Thanks.
I'm just quoting what looks like incorrect statements to me. I've been fiddling with Audis before this car
Old Jan 4, 2012 | 10:52 AM
  #282
Thanks.
That statement you quoted (which was made by me, on my personal account. Yea, I wrote this How-To) is NOT incorrect. The pill by the solenoid has a bigger hole then the pill by the turbo.
What kinda Audi did you used to own? Im an ex B5 S4 owner.
Old Jan 5, 2012 | 09:38 AM
  #283
ViciousLSD's Avatar
GIAC 1.8t
Old Apr 17, 2014 | 05:14 AM
  #284
-Dome-'s Avatar
Hi Friends,
I have the Boost Pill Mod with a 0,6mm Hole in the Pill. In the Ecu i have WGD 100%, Boost Desired Engine Load 159, Offset 120, Error Correction is all 0.
The Load is Peak 240. Boost Leg tested, Solenoid tested.
Map is Tephra V7.
Can anyone Help me?
Old Apr 17, 2014 | 05:29 AM
  #285
-Dome-'s Avatar
Hi Friends,
The Load is Peak 240. Boost Leg tested, Solenoid tested. All other Pills removed.
Map is Tephra V7.
Can anyone Help me?
