Air Volume Reading?
Old Oct 10, 2006 | 11:52 PM
coolguycooz's Avatar
Air Volume Reading?
Im new to using evoscan? I just rolled out with .97 and the Air Volume readings are jumping up and down all over the place . Is that normal or whats up?
Old Oct 12, 2006 | 05:20 PM
still wondering, if anybody knows whats up with the air volume readings. Im pretty sure its messed up with evo scan, cause its jumping around all over the place even at idel.
Old Oct 12, 2006 | 05:36 PM
MalibuJack's Avatar
Can you be more specific? Which column are you talking about? I don't recall a column called "air volume"
Old Oct 12, 2006 | 05:41 PM
yep its exactly that in the .97 version. Its called Air Volume, the reason why i think its messed up or incomplete because under *Units* its the only one thats blank. All the other readings have something there. like % RPM Deg F and stuff.
Old Oct 12, 2006 | 05:46 PM
MalibuJack's Avatar
Which requestid is it? And what formula is it using? MAF readings do bounce around a bit..
Old Oct 12, 2006 | 06:02 PM
the request is 2C and the function is just X.
So it could be working properly, i mean its jumping up and down ridiculously. and throttle dosent change its readings.
Old Oct 13, 2006 | 09:35 AM
Rob W.'s Avatar
Jack: I think Air Volume came out with version 0.95. I have no idea what the data actually is though.
vizi0n
Lancer Troubleshooting
Oct 23, 2016 06:55 PM
christianreed91
Sep 11, 2016 09:12 PM
snafufx
Jan 31, 2016 02:26 PM
unclecomfort
Jan 18, 2006 07:51 PM
EVOnoir
10
May 1, 2005 08:43 PM
