Opinion on low and high maps.
The knock link was good "in its day" since it was better than nothing..
The TurboXS UTEC's knock detection did a decent job also, it couldn't discriminate differences in frequencies, but it was able to adjust the sensitivity at different RPM ranges where the voltage threshold was different for those levels.. I had experience where the knock detection on the UTEC was fairly consistent with the stock ECU, only not quite sensitive enough in its stock settings.
I agree about the tuner pro's knock sensor, only its mainly because of the location it gets mounted.. the closer you mount it to the stock location, the better it will read.. But its value is in being able to listen to it yourself and let your brain do the knock detection.. I was using that very sucessesfully (I still do when I am trying to determine if knock is noise or real knock, thats how I found the clunking of my downpipe)
it reminds me of when I use my stethlescope at work.
But sounds much different. hehehe
tephra
14
Aug 23, 2010 08:27 AM
03RRVIII
Jun 10, 2008 01:54 PM
