Need evoscan.txt for latest evoscan + dll
Old Oct 31, 2006 | 12:03 PM
justchil's Avatar
Hey guys I've fallen behind in the ECUFlash scene... I'm trying to find an evoscan.txt for the latest Evoscan version to use with DLL. Having your Data.xml from evoscan might be helpful too if you've made any changes.
I'm really wanting to make some of those HP/TQ graphs in DLL to see how they compare to my last dyno... They look really neat and could give me some idea in power changes.
Sorry for being such a noob.. just no time to get caught up on reading as of yet
Old Oct 31, 2006 | 12:07 PM
justchil's Avatar
Hmmm
I wonder if all the data needed to calculate a dyno plot in DLL can be logged via Malibujack's Mitsu logger release A? I see it came with a txt file for DLL I'll probably end up answering my own questions shortyl
Old Oct 31, 2006 | 12:11 PM
Rob W.'s Avatar
That's a good question. I bet everything is there. Either way, go to Aktivematrix.com and download it. I'm almost certain he includes the latest evoscan.txt file in the Mitsu Logger archive.
Old Oct 31, 2006 | 12:38 PM
justchil's Avatar
I've got it locked and loaded.. I doubt I'll be able to really test it this evening with all the kids roaming the streets... but i can at least see if it works
Old Oct 31, 2006 | 12:56 PM
Rob W.'s Avatar
Remember that you want a level, straight stretch of road to make the HP/torque estimates as accurate at possible. Ideally, you'd use the same stretch of road and average the results in each direction.
Old Oct 31, 2006 | 02:41 PM
justchil's Avatar
I only got 2 WOT pulls today coming home on flat ground... both pulls I let off shy of 6000.. both were pretty much the same 360ft/lbs 390hp peak. For kicks I had the yellow spring in my dv today just to see how it handled under normal driving.. it does great but does leak like crazy.
This is sweet I'm using the Mitsu logger by MalibuJack... I'm loving it so far!
Old Oct 31, 2006 | 03:59 PM
chmodlf's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=229759
Old Nov 3, 2006 | 12:50 PM
justchil's Avatar
Well it didn't work with the evoscan log for some reason.. the timeformat (i think) colum is different than malibujacks logger. I think I may just ditch evoscan and use mj's mitsu logger from now on
Old Nov 6, 2006 | 10:30 AM
justchil's Avatar
I had something screwed up with my evoscan upgrade... uinstalled/reinstall and it works fine. Load doesnt work so I'm assuming we have to put our scale setting and voltage in the data.xml file.
If only MJ's scanner would log AFR I would ditch evoscan
Old Nov 6, 2006 | 10:50 AM
justchil's Avatar
here is a couple graphs.. nothing to great.. this is on my street tune 25psi with a set of fouled plugs (the white is almost black)
Old Nov 6, 2006 | 01:46 PM
justchil's Avatar
Another one.. this is the best one so far
I'm curious to see what happens when I put fresh plugs in tomorrow
Rall1boy
15
Aug 16, 2012 06:42 AM
Creamo3
Nov 6, 2010 09:58 AM
EVO8LTW
Mar 9, 2009 07:13 PM
Mellon Racing
Dec 18, 2007 07:19 PM
Liqquid
May 19, 2007 10:35 AM
