Help, car will not start
Old Nov 2, 2006 | 07:26 AM
evo8dad's Avatar
Help, car will not start - FIXED!!!
I hooked up the ECUflah cable for the first time last night. The only thing I did was download the ROM and change the Rev limit. When I wrote to the ECU I forgot to select the advanced function to obtian the immobilizer code but, I did not change anything else except the Rev limit, so I do not think that is the problem.
I am also currently running a ECU+. I snipped the OBD wire as per the instructions and installed quick connects, however, for some reason that function now does not appear to be working either.
I do have a SES but, so far have yet been able to pull it.
Just ignore this. The ECU+ connectors came just ever so slightly loose causing a crank shaft position code, which does not allow the car to start
Help please I am currently stuck in my garage trying to figure this out
Old Nov 2, 2006 | 07:56 AM
MalibuJack's Avatar
I was going to say, check your wiring harnesses, they always tend to be the first place I look when stuff happens..
Old Nov 2, 2006 | 08:01 AM
vii omega ix's Avatar
give the car a quick look over and make sure nothing else is happening that you might have missed. . . did you start the car last night after doing all this work
Old Nov 2, 2006 | 09:09 AM
evo8dad's Avatar
Thanks guys. My pants got a little heavier when it wouldn't start hence the panic but, everything is a okay now
Old Nov 2, 2006 | 09:11 AM
AlwaysinBoost's Avatar
I'm pretty close to Sellerville, if your still having a problem shoot me a PM with your contact info. I'll swing by tonight and see if I can't help.
Old Nov 2, 2006 | 09:12 AM
n/m, I see you got it fixed. good job.
Old Nov 2, 2006 | 09:25 AM
evo8dad's Avatar
Thanks for the offer though. Maybe I'll take you up on it when it comes time for some road tuning
