Macs and ECUFlash/Evoscan
Old Feb 1, 2008 | 05:14 PM
Inprogress's Avatar
So using boot camp or parallels is not an option when trying to log and use ecuflash?
Old Feb 1, 2008 | 05:17 PM
donour's Avatar
I've verified: both work.
d
Old Feb 1, 2008 | 05:43 PM
Inprogress's Avatar
But still no support for widebands though right? Unless I run it off bootcamp/parallels?
Old Feb 1, 2008 | 08:21 PM
donour's Avatar
I general? I don't know. There are dozens of different widebands available. One of them might have a Mac logger.
I suppose you could probably use the output wideband in one of the stock ECU inputs, then log with MacLogger. That would be...um...technical, however.
d
Old Feb 1, 2008 | 08:23 PM
Inprogress's Avatar
Ah, but running Evoscan/Ecuflash through bootcamp/parallels and I should be fine right? Have you had any experience running ecuflash/evoscan through bootcamp/parallels?
If so which, works better?
Sorry for all the questions, I just really want a MAC, but also need a laptop to tune and what not.
Old Feb 1, 2008 | 08:37 PM
donour's Avatar
Yeah, I just said that.
d
see?
Although you don't really need parallels/windows for ecuflash, you may want it for logger tool XYZ (there are several of them). Mine (MacLogger) is admittedly limited, but hey it's free!
d
Old Feb 1, 2008 | 08:40 PM
Inprogress's Avatar
Yeah I only ask about parallels/boot camp so I can run Evoscan, so then I figure I may as well make sure that I can run Ecuflash and Evoscan at the same time in boot camp or parallels, which you've said I can so I'm SET! I'm friggin hyped!!
Thanks donour!!!
Old Feb 2, 2008 | 07:38 AM
Inprogress's Avatar
donour,
Which versions of ecuflash/evoscan did you use through parallels/boot camp successfully?
Old Feb 2, 2008 | 04:36 PM
donour's Avatar
donour,
Ecuflash 1.32 was the last version I bothered to update to. The developer has a Mac though, so support is pretty good.
I haven't really ever used Evoscan. I have a license, but I don't really like it. I verified it worked about 18 months ago, but I usually use my own logger.
d
Old Feb 2, 2008 | 05:47 PM
Fairclough's Avatar
I just downloaded EvoScan v 2.0 and i can't open the program, I have a Compaq with Windows XP.
Old Feb 2, 2008 | 07:39 PM
codgi's Avatar
Wrong thread . Whats the error message?
Old Feb 2, 2008 | 08:24 PM
Inprogress's Avatar
d
Yeah I just got v1.34 to work on my mac with an updated XML file to include JDM MAP and 2-byte, I'll be installing XP SP2 via Boot Camp tonight and will find out soon enough if Evoscan works on it. I've heard from another EvoM member that version .97 works but 2.0 doesn't. I'll see what happens.
Old Aug 18, 2008 | 08:54 PM
w evo's Avatar
any news on how evoscan .97 or 2.0 worked via bootcamp?
Old Aug 19, 2008 | 07:24 AM
justboosted02's Avatar
i couldnt get ecuflash and logworks to work with my macbook pro running parrallels and Vista ultimate.
although i didnt try to hard and i just use my old laptop with XP now
Old Aug 19, 2008 | 09:15 AM
donour's Avatar
Ecuflash runs natively on Mac.
d
