inyector change
Old Nov 21, 2006 | 08:43 AM
EVO2003VIII's Avatar
Thumbs up inyector change
Hi to all:
Just a simple question about ecuflash.... i'm planning to change my inyectors, what changes do I have to do so they can work?
thanks
Old Nov 21, 2006 | 11:42 AM
RazorLab's Avatar
Injector scaling and Injector voltages
Old Nov 21, 2006 | 05:32 PM
my inyector size es 1000cc can the inyector scaling and voltage can work for that application>
Old Nov 21, 2006 | 05:37 PM
l2r99gst's Avatar
Yes
Old Nov 22, 2006 | 06:29 AM
well thanks a lot guys for the help, when there is a problem with something and people help is good to know that there are still good people out there.
Also yesterday I tried to download an evo9 rom but seems to be that is locked. Can it be posible to enter to it. ? The guy said that someone made him a flash. Thanks for any help here....
Old Nov 22, 2006 | 06:53 AM
MalibuJack's Avatar
Well, first, its wrong to use someones map if it was created by a tuner for him. He shouldn't be distributing it as its probably a violation of the agreement he has with his tuner.
Technically its not really locked, its obfuscated. If its locked, that would mean the init code on the ECU has been altered, and many of the obfuscated roms are also locked.
I just reread your post, if your trying to download it off another EVO and its saying no response to any known code, then yes, its locked..
Although knowing that you are attempting to extract a tuners map from another car for your own use, I cannot give you any info on how to do this, the search feature is your friend.
Old Nov 22, 2006 | 08:05 AM
Well, basically I don't need to see others reflashes because I know how to do them, it's that when they dyno tune it it was fine there but he asked me to put on my tech edge wbo sensor on the streets and the engine is runnig very lean.....I only wanted to help him since the one that made his reflash it's not here at puerto rico and that is his daily driven car.
The engine is not safe to run it the way it's suppost to do. Someone told me that there is a unblocker that I can use. I only want to rich the fuel and take it where is suppost to be.
Thanks
Old Nov 22, 2006 | 08:47 AM
MalibuJack's Avatar
Yep, sounds like a plan.. But you can use the unlocker and do what you need to do.. Like I said, its posted in this forum so you only need to search for unlocker..
Old Nov 22, 2006 | 09:08 AM
I register yesterday to the site aktivematrix, but it seems that I'm not in today. Do they take that long?
Old Nov 22, 2006 | 09:21 AM
MalibuJack's Avatar
You should get an activation e-mail almost immediately after registering.. Its likely your mail server treated it as Spam or Junk mail.. Check the spam/junk mail folder for a message from the website..
This is a pretty common problem thanks to the huge amount of spam and pretty strict spam qualifier rules many public email servers use..
I really need to post a huge FYI/FAQ about this on my site..
I know of several people who had a problem this week so I'll re-send all of them today..
The easiest way to solve the problem is to add sysop at aktivematrix.com to your allowed senders list (or the entire aktivematrix.com domain) since I don't send unsolicited e-mail its pretty safe to do that.
Old Nov 22, 2006 | 09:50 AM
EVERYTHING ok, activation complete. I have now the ecu unlocker....
I will let you know if everything work fine.
thanks
