EVO flash
Old Nov 25, 2006 | 06:45 AM
Joshs EVO's Avatar
EVO flash
I have a 05' and I have some new parts that I will be installing soon and I would like to get the ECU flashed. The guy I bought it off of got a mail in flash from turbotrix and the car idles all weird and stuff. I have added some things since buying the car. Is there a mail in flash or something that they can do a custom flash to my exact parts I have on the car?
Old Nov 25, 2006 | 07:47 AM
nj1266's Avatar
Get in touch with TTP and he will take care of you. He will create a flash for your car. All you have to do is flash it in the car. So you will need to get the Tactrix cable. With that cable you can log parameters from your ECU using Evoscan ($25) or Mistulogger (free). Then you can e-mail the logs to TTP and he will tweak your flash and make it even better. I think that is the best method to tune from a distance.
Old Nov 25, 2006 | 09:49 AM
ghoonk's Avatar
nj1266, which parameter should I log using mitsulogger? What are the correct settings to use:
Baud Rate = 15625?
Check Load0, Load1 and Load2?
Injector Scale = 513?
Latency @14V = 0.432?
Check 2 byte response?
Thanks
