stock Iridiums vs NGK BPR7ES
Old Jan 8, 2007 | 10:38 PM
  #31
hondafan's Avatar
Originally Posted by AlexEvo
hondafan, finally a straight answer from someone. i appreciate that! ive been debating whether or not to use these or return them and cough up the 100 for a set of stock plugs for a while now. i ran these in my subaru and in a toyota v8 i had and no issues, i figured if they're good enough for those they're good enough for the evo. thanks!
no problem. i've run those for 35K miles without a hitch, same gap and everything at 22-23 psi. i had a brief 1K mile stint with the coppers and my car didn't respond well to them at all, so i'd say you're making a good decision based on my experience.
Old Jan 10, 2007 | 11:29 PM
  #32
AlexEvo's Avatar
i recently had a fixin to figure out what all the spark plugs are about and this is what i discovered. In reference to iridium plugs, B im assuming means Car, K means small 5/8" socket for installation, P means 13/16" socket size for installation, R i dont know, 7 = heat range(obviously), E i dont know, and IX = Iridium.
In reference to copper plugs, B = again i think means car, P instead refers to Protruding electrode tip as opposed to meaning socket size used for install, R/E no idea, and S im 90% sure means Copper.
The plugs i compared to gauge my educated guesses were, B7ES, BR7ES, BPR7ES, BPR7EIX, and BKR7EIX.
Old Jan 11, 2007 | 06:29 AM
  #33
mitsuorder's Avatar
P is in reference of the protruding tip so the br8eix is simply a non-protruding variant of the plug.
Old Jan 14, 2007 | 07:19 PM
  #34
Sleeper2G's Avatar
i use the unobtainium plugs, but I have a AmEX black card J/K
Old Jan 14, 2007 | 07:21 PM
  #35
Sleeper2G's Avatar
o seriously though I used the bpres7 s in my 1g in a a 2g then ranthe iridiums and I logged a lot better mpgs
Old Feb 6, 2008 | 08:20 PM
  #36
wizzo 8's Avatar
So the 05's come with iridium plugs. Should I get the bpr7EIX or bpr7ES?
Old Feb 6, 2008 | 09:42 PM
  #37
C6C6CH3vo's Avatar
Good question
Old Feb 7, 2008 | 05:20 PM
  #38
mitsuorder's Avatar
all evo's come with iridiums. try a non protruding tip eix in whatever heat range you prefer and you'll like it.
Old Feb 7, 2008 | 05:29 PM
  #39
wizzo 8's Avatar
I got some BPR 7EIX. Gapped at .028 Is that a good gap?
Old Feb 7, 2008 | 05:41 PM
  #40
mitsuorder's Avatar
.027 is usually the largest gap I rock for around 22/23 psi but if you're not getting blow out and the car pulls with a proper afr then go with what you can get away with
Old Feb 7, 2008 | 06:01 PM
  #41
wizzo 8's Avatar
Im at 21-22 psi but am getting a custom tune soon. Should I change it to .027? I went with .028 because that was the OEM spec min.
Old Feb 7, 2008 | 07:00 PM
  #42
C6C6CH3vo's Avatar
Would irridiums have less flame propagation delay by any chance?
Once noted a direct 1 -2 psi boost drop just from swapping to the BPREIX. The only thing I can think, ignition wise, that can cause this from just a plug is shorter ignition lag - which is the same as ign advance. This'l raise cht's but lower turbine inlet temps dropping boost.
Old Feb 7, 2008 | 07:30 PM
  #43
wizzo 8's Avatar
Ok now Im . Which plug is better for HP. Stock Iridium, NGK BPR7EIX or BPR7ES?
Old Feb 7, 2008 | 07:37 PM
  #44
mplspilot's Avatar
So i'm using non-protruding plugs right now. And i've been reading some stuff on plugs and a lot of places say that a protruding tip ignites the flame in a more optimal place of the chamber making for a quicker burn. Essentially this is what we all strive for - quicker burn. (which means you'll get the same timing at a smaller ignition advance - a good thing)
So i'm thinking about switching back to protruding one.
Anyone have any thoughts on this?
Last edited by mplspilot; Feb 7, 2008 at 07:44 PM. Reason: better not confuse anyone
Emperor 4g63
16
Jun 8, 2017 12:50 PM
slipperychicken
Feb 27, 2016 10:27 AM
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
Charlie_B
10
Jul 1, 2007 06:49 PM
Villan
23
Sep 17, 2004 08:32 AM
