Boost with Ecuflash
Old Dec 9, 2006 | 12:12 AM
Evo_Jay's Avatar
Originally Posted by nj1266
Yeah, I read that thread. But most are trying to control boost by removing the solenoid pill or resizing it. I want to set peak boost to 22-23 psi peak and let it taper to about 19-20 w/o removing the stock pill or using a modified one.
Is that doable given the tables I posted?
I can usually get 20-22psi out of the stock BCS without modifying the pill near the turbo, but WITH removing the pill near the solenoid.
So i dont know if you can get 22-23 without removing any pills.
Old Dec 9, 2006 | 01:32 AM
spdracerut's Avatar
I just datalogged my car (completely stock, stock maps) for the first time, but it was just driving around during lunch, so no really good data. BUT, I am getting some knock around 3500-4000 rpms (2-6 knock sum which caused the car to pull some timing); so around peak torque. My boost also spikes to 1.5-1.6 bar depending on the air temp.
Any info on the stock MAP sensor, or rather, how accurate it is? It maxes at 328.164 Kpa according to Evoscan, which translates to roughly ~23 psi (328 kpa - ~105kpa idle reading = 223 Kpa. Idle = ~ -65 Kpa. So measured boost = 223-65Kpa = 158 Kpa = ~ 23 psi).
I'm getting the 328.164 Kpa reading up to 5.5k rpms which is as high as I've datalogged so far. But it doesn't seem to correlate to my boost gauge which recorded a peak of 1.6 bar (~23.2 psi) but quickly tapered off aftewards.
So it seems to me that the stock MAP sensor is just about worthless. I'm going to try to get a lot of good data this weekend with everything completely stock and then start tweaking the car (boost, fuel, and timing). It's a bit aggrevating that I'm getting knock with everything completely stock. Damn this Cali gas!
I'm actually thinking of reducing the Boost Desired Engine Load (as opposed to timing) around peak boost and peak torque since I'm getting some knock there. Part of the reason is that according to the Evo specs, it's only suppose to hit 20.31 psi at 3500rpm/WOT and I'm hitting at least 21.75psi. I need to see how my boost changes with RPM though... I'm going to have to do it ghetto style and use a vid camera
Old Dec 9, 2006 | 02:48 AM
jcsbanks's Avatar
heyzeus11 has pretty much answered nj1266. I would set one of the maps (say 150+100 mid, tapering to say 120+100 at the top or whatever you want/your engine likes/needs) and simply copy to the others.
I run 285 fuel cut with 1000ms delay. So it will cut the fuel if the load is over 285 for 1 sec. It does work as I have tested it. I see no advantage at all in disabling fuel cut, you're just removing safety devices.
Old Dec 9, 2006 | 02:49 AM
jcsbanks's Avatar
racerut, AFAIK only JDM/UK IX have the 3 bar MAP sensor. It is very useful if you have it.
Old Dec 9, 2006 | 07:41 AM
nj1266's Avatar
Ok, Based on the advice from jcs and heyzeus, I came up with the following boost mix. Please tell me if this will give me the 22-23 psi and taper to 18-19 like I have with the xede.
I did not set the three boost tables the same. I simply tapered 1 and 2 differently than before.
Should I taper the boost limit table like the stock one does, ie, set it @ 275 and then taper it below that from 6k rpm.
I welcome all opinions on this. Thanks for all the help so far.
Old Dec 9, 2006 | 08:15 AM
jcsbanks's Avatar
I would get rid of the dip at 3500 RPM, and make table 2 the same as 1 & 3. Unless the wastegate jams shut you won't be able to get 275 load at high revs on the stock turbo. I would run it at 20 above target through the rev range ie 251.9 at 7000.
Old Dec 9, 2006 | 09:08 AM
spdracerut's Avatar
JCS, you're lucky with the 3bar MAP sensor! I'm not quite sure why mine (05 Evo) works the way it does.... reads ~105 Kpa at idle which is pretty much the same as the barometric. It should only be reading ~34 Kpa due to the vacuum... well, unless it's before the throttle body. If that were the case though, then the 328 Kpa would translate to ~32 psi and I'm sure as heck not getting anywhere close to that. So it doesn't quite make sense.
Naji, did you have to take out one of the stock restrictor pill in the boost line for the Xede? If so, make sure you put it back in before you try running those boost maps.
Old Dec 9, 2006 | 09:39 AM
nj1266's Avatar
Yes, the pill was taken out. I will put it back in and zero the xede tables if/when I test the flash that I am working on.
Old Dec 9, 2006 | 10:06 AM
nj1266's Avatar
Question for all the guys:
The LoadCalc on my car @ peak boost/torque 3700-3800 rpm is between 250-255. How does that impact the table set-up? Should I set up the boost limit table to between 250-255?
Old Dec 9, 2006 | 10:12 AM
jcsbanks's Avatar
Sometimes loadcalc is a bit optimistic.
If you are now using external boost control and you want the same boost then set the target to what you think your load is now.
Set the boost limit comfortably above this so you only get a fuel cut if there is a fault.
Old Dec 9, 2006 | 08:41 PM
nj1266's Avatar
That is what I want to do. I currently have the xede controlling boost with a 22-23 psi peak and a taper to 19 psi by redline. @ peak the car loads to 250-255. By "target" do you mean the three desired engine load tables? So set these to 255-100=155. Stock they are set @ 159.4 till 3500. Set them to 155 above that?
I set it to 275, but that was too high according to you. What do you recommend?
Old Dec 10, 2006 | 02:50 AM
jcsbanks's Avatar
I'm giving examples to show the method, not saying what is too high or too low for your setup.
A disabled fuel cut with a virtually infinitely long timer and unachievable boost limit is bad practice IMHO.
If you are happy with your present boost control, then I suggest you datalog the best measurement of load that you can across the RPM range in the highest gear that it is safe to do so, then set the load values (in all three tables) you log as your targets (smoothing them out, minus whatever you set the offset to).
If you can't achieve these then you need to look at restrictor/actuator/solenoid changes.
Old Dec 10, 2006 | 02:59 AM
jcsbanks's Avatar
If you want my best guess as an idea:
Leave everything as your last screen dump that you posted, except...
Boost desired engine load 1,2,3: 155 all the way from the bottom to wherever you want to start it tapering - say 5000 RPM? Then about 125 at red line - or whatever your present redline load is minus 100 (because your offset is 100).
Personally, my tune is quite aggressive for pump fuel, but I run a fuel cut of 285, and the actual load I run is about 265 through the midrange, tapering to about 245 at 6000, 230 at red line.
Old Dec 14, 2006 | 07:38 PM
mlancerevo8's Avatar
i need help tuning... my cars way too rich i have leaned it out but still too rich on a mbc at 21psi.. anyone got sugestions...
Old Dec 16, 2006 | 04:25 AM
cij911's Avatar
jestrtuning.com
