Brand of cable for serial to USB?
Old Dec 10, 2006 | 02:28 AM
coolguycooz's Avatar
Ok so i got my zeiotronix, now i know all you have to do is simply run to radio shack and pick up a serial to usb conversion, but ive read posts of people buying cables that didnt work. So i was wondering if somebody could give me the brand of cable that worked? so i dont have to go back and forth returning cables? i just wanted the exact brand that somebody uses?
Old Dec 10, 2006 | 03:13 PM
ant_turbo's Avatar
I'm using one that I bought FRY'S works great!! Just make sure you setup the right comm port!! It comes with drivers to!!!
HERE'S A LINK FOR IT!!
Old Dec 10, 2006 | 04:00 PM
dryad001's Avatar
I have a radio shack cable and it doesnt work.
Old Dec 10, 2006 | 04:03 PM
kreionic's Avatar
Not to high jack your thread but is it the same cable for all widebands? Could I use that cable for the AEM
Old Dec 10, 2006 | 04:25 PM
ant_turbo's Avatar
I would suppose so!!
Old Dec 10, 2006 | 05:18 PM
LimPShoT's Avatar
I went to radio shack and they wanted $35 for a serial to usb converter so i went to frys and got one for $15 works great you just need to make shure to look up your com port settings in device manager and change to which com port you want to use in zeitronix software.
Old Dec 10, 2006 | 09:07 PM
and com port being for example my lap top has 3 usb ports, if i plug the tactrix in to 1 and the wideband in to 2 i would select com port 2 right?
Old Dec 11, 2006 | 02:33 AM
evo4mad's Avatar
nah you can still select com1 for your wideband (usb converter), your tactrix can be set to com 23 or whatever by default it doesn't matter, because EvoScan and EcuFlash use a direct usb port access and ignore the port number.
Old Dec 11, 2006 | 04:41 AM
steevo's Avatar
check out http://www.socketcom.com/. They have the best add-on serial ports available. Very consistant. I wouldn't use anything cheap.
Old Dec 11, 2006 | 08:39 AM
A418t81's Avatar
Well I have the fry's one and still the same problem. Logworks works flawlessly and instantly picks it up while Evoscan spits out nothing but garbage numbers when looking at the correct com port. That makes 3 adapters that work for EVERYTHING but evoscan AFR logging, all other aspects of the usb-serial adapter work fine.
Old Dec 11, 2006 | 10:17 AM
Magnumpsi's Avatar
I use the radio shack usb to serial for eveything every time i tune. AEMs, UTECs so on and so fourth and have never had a problem with it.
Mitch
Old Dec 11, 2006 | 11:28 PM
RazorLab's Avatar
I use this:
http://www.pfranc.com/usb/usb.shtml
It works for everything I Have needed it for so far. zeitronix, AFR logging in evoscan, ECU+, etc
