ECUFlash / Evoscan / Mitsulogger Questions
Old Sep 27, 2008 | 11:52 AM
  #436
D-VO's Avatar
Originally Posted by Tx4Codeman
Mine has not been modified, as its value is still 15625.
Did you check the fuses? Me and a buddy were messing around pulling fuses and with a couple of them out, evoscan won't work.
Old Sep 27, 2008 | 01:20 PM
  #437
sponners's Avatar
ecuflash
hi guys,
noticed on ecuflash that the list on the left (with the check box's) each one is written in black text.
some are 'greyd' out - these obviously haven't been opened and can't be used.
but some I have (mainly being the ALS tables are in blue text.......why is this?......I can open these up and adjust settings but am wondering if they are actually activated/working?
thanks for the help.
Mark.
Old Sep 27, 2008 | 06:16 PM
  #438
Psquared's Avatar
Quesion: Recently, and for NO reason my laptop decided it won't connect to the ecu in any way. It won't read from, or write to the ecu. It read from another local guys car here, but only after trying 4-5 times. I am running XP and Vista in a dual boot. Neither will connect. It worked totally fine yesterday. I'm dialing in injectors, and flashing new latencies. That's it...any ideas??
Old Sep 28, 2008 | 09:20 AM
  #439
D-VO's Avatar
I just went through the same nightmare. Mine was really wierd though. Did you change anything at all? Is the USB port damaged? Check the USB controllers in the device manager. Does anything show it has an issue? How long has it been since the last time you tried to use ECUflash?
Old Sep 28, 2008 | 09:35 AM
  #440
D-VO's Avatar
Have any of you guys tried to mess with the baudrate for ECUflash/evoscan? I had done the modification for the baudrate last year on another version of ECUflash that has since been deleted. However, with the new version 1.38, no matter where I try to set the baudrate, EVOscan will only work with 62500. This one's really wierd.
Old Sep 28, 2008 | 09:37 AM
  #441
Jack_of_Trades's Avatar
I used to do the 62500 ROM modification but I set it back to 15625. Didn't see enough of a difference to bother with it. If evoscan only works with 62500, that means your ROM is set for 62500. You need to reset your ROM back to 15625 to log evoscan at 15625.
Old Sep 28, 2008 | 09:39 AM
  #442
D-VO's Avatar
Hey since you live kinda close, do you want to meet up somewhere to try to figure it out?
Old Sep 28, 2008 | 09:46 AM
  #443
D-VO's Avatar
See that's the problem though. If I set it to 15625 on ECUflash, evoscan will still only read at 62500. If I set it on 50000 on ECUflash, it still only reads on evoscan at 62500. But if I set ECUflash on 62500, evoscan won't read at 15625,50000, or 62500. I can't get it to read 15625 on evoscan at all.
I'm not sure if it has something to with changing the code, flashing it to the ECU, then deleting ecuflash and re-installing a newer version. See? The only thing I changed was upgraded to a newer version of ECUflash.
Old Sep 28, 2008 | 10:04 AM
  #444
Then there is something wrong with your baudrate table in ECUFlash. Maybe the endian???
Old Sep 28, 2008 | 11:22 AM
  #445
D-VO's Avatar
I'm pretty sure this is right. The endian reads "big". Does it matter how close the </table>'s are from eachother?
File Type: txt
note.txt (560 Bytes, 2 views)
Old Sep 30, 2008 | 07:53 PM
  #446
Tx4Codeman's Avatar
When removing that particular fuse, did it prevent ecuflash from being able to use the tactrix cable also?
Where in ECUflash do you check the baud rate?
-This wouldn't entirely make since. Another laptop with the same baudrate on evoscan (15625) is working on my car.
Old Sep 30, 2008 | 11:24 PM
  #447
D-VO's Avatar
Yes. I was using the tactrix cable when we removed the power locks fuse. Neither evoscan or ECUflash works without the power locks fuse in.
Did you try evoscan 2.5 on your XP OS? I remember seeing a thread somewhere with someone else having a problem with vista. I'll see if I can find it.
Old Oct 1, 2008 | 02:42 PM
  #448
Tx4Codeman's Avatar
My tactrix cable is working with ecuflash / obd scan tech, just not evoscan. It has to be the program itself, not my ecu or cable.
Under your logging tab, Select Usb/Com/Elm, is COM1 stuck checked? I can have my tactrix plugged into 'com4', but am not able to select it. Meanwhile, under USB, tactrix 1.3b is selected. Oi.
Old Oct 1, 2008 | 04:12 PM
  #449
AlwaysinBoost's Avatar
i'm having no luck getting evoscan to work either. ECUFlash is connecting/reading fine though which is weird.
the ONLY way I can get EVOScan 2.5 to connect is if I check one of the WB boxes and leave all the other parimeter unchecked. then it will connect and log the WB channel even though I don't have a WB hooked up to the computer. if I attempt to check any of the other boxes like TPS or RPM it won't connect. anyone have any ideas????
Old Oct 2, 2008 | 02:32 PM
  #450
gsrboi80's Avatar
Need a little help guys
Ok I have my wideband pinned to my ECU for logging. Rear O2 disabled obviously
So I had to mod the XML in EVOSCAN with this line IIRC and enter my formula for my wideband
<DataListItem DataLog="Y" Color="" Display="Wideband AFR" LogReference="WideBand" RequestID="12" Eval="0.0274*x + 9.0" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="22" ChartMin="0" ChartMax="22" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
My question is can I do this in Mitslogger? If so, is the text line the same as EVOSCAN? What is it? Where in the XML do I insert it?
THNKS GURUS
