ECUFlash / Evoscan / Mitsulogger Questions
Old Nov 27, 2008 | 04:55 AM
  #496
Redline06's Avatar
is the 1/3 cable fine with 1.40??
BUMP for my Q..
Originally Posted by Redline06
okay i just dl v1.40 and I want to know which cable do I use..? I've been out of the game for a while.. cant find my 1.3, so b4 i buy another one.. which one do i buy.. I heard there's a new one out there..lol
Old Nov 27, 2008 | 07:42 AM
  #497
brandEvO's Avatar
If you go on Evoscan's website, they have the 1.3 cables there. The new cable is the 2.0, I heard there is problems with it working with Evoscan. They did just realease Evoscan v2.6 which has a spot to check off that you have a 2.0 cable.
Now Bump for my question! lol
Old Nov 29, 2008 | 07:29 PM
  #498
chaotichoax's Avatar
I was searching around to try and better understand 2 byte load...and have a question
if I add the code and the mut valves and what not
does it change anything within my tune or is it strictly a means of better load calc?
will it do anything but log differently?
Old Nov 30, 2008 | 11:07 AM
  #499
D-VO's Avatar
I loaded the two byte mod about a month ago, and noticed the readings have a 10% difference. Where I'd get a 227 load at 7000rpm on one byte, I get 214 load at 7000rpm with 2byte. I just end up using both readings to tune.
Old Nov 30, 2008 | 12:41 PM
  #500
Bigdon's Avatar
Has any one sorted out how to fix the hang problem with v 1.4?
I installed v 1.4 on a clean lap top and it works fine.
Old Nov 30, 2008 | 08:46 PM
  #501
anyone else?
Old Dec 1, 2008 | 07:34 AM
  #502
Mellon Racing's Avatar
2byte load is just a little more accurate for logging, that's all. It doesn't affect the tune itself.
Old Dec 1, 2008 | 01:42 PM
  #503
thanks mellon appreciate it
Old Dec 1, 2008 | 01:54 PM
  #504
anytime!
Old Dec 1, 2008 | 01:58 PM
  #505
SLO-EVO's Avatar
is the man...
Old Dec 2, 2008 | 04:21 PM
  #506
bevolucion's Avatar
well I got the zeitronix all hooked nd ready to tune, and now all of a sudden I try mitsulogger and I cant get any info bcause this. It also says that the openport 1.3 is I guess unreadible,the weird part is that I try it on idle and it collects data the error coms when I go open throttle.
error messege
JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Old Dec 4, 2008 | 04:35 PM
  #507
bevolucion's Avatar
answer me^^
Old Dec 15, 2008 | 03:00 AM
  #508
SeanV's Avatar
Has anyone been able to get the new LM2 wide band to work through Evoscan 2.6?
I am unsure how to go about..... ?
Thx
Old Dec 17, 2008 | 12:59 PM
  #509
raasfaas's Avatar
I have a question about tuning timing on the IX's, given that they come with 3 ignition maps, is the best way to make the changes across all 3 maps (make all 3 identical) or do you tune a specific one.
Old Dec 21, 2008 | 08:26 AM
  #510
nj1266's Avatar
Make all three high octane iginition maps the same. The ECU interpolates between them, but we do not know the interpolation logic, so we make them the same.
