ECUFlash / Evoscan / Mitsulogger Questions
Old Mar 9, 2009 | 08:19 PM
  #541
Gatecrasher R/T's Avatar
How about a download link to the last 4 or 5 updates for those of us who paid up for licenses?
Old Mar 10, 2009 | 04:43 PM
  #542
nitz's Avatar
i just got my lc-1 back from innovate who flashed it to resolve erratic behavior. it works perfectly now except with evoscan. log works 3 displays the correct afr , but evoscan displays readings like 4.332 at idle. anyone have an idea what could be wrong. it does this in every single version of evoscan.
thanks
Old Mar 11, 2009 | 03:09 PM
  #543
kyoo's Avatar
Is there a 64 bit/Vista version for ecuflash/mitsulogger? I tried searching, but I haven't come across any actual solutions
Old Mar 11, 2009 | 04:00 PM
  #544
SavEVOIX's Avatar
My rear 02 sensor has gone bad. With the 02 sim out there what must I do to get rid of my check engine light and get this fixed? I picked up a Bosch 15733 4 wire 02 sensor. Where do I download the sim and what else do I need to do? Will I need to re-tune my car or am I fine with a simple install + flash?
Old Mar 14, 2009 | 12:14 AM
  #545
fostytou's Avatar
EvoM Community Team
I have a feature request... is there any way to not just gray out, but not even display the items that weren't logged when viewing the graph of a log?
Old Mar 14, 2009 | 07:23 AM
  #546
alloutDSM's Avatar
i cant get my openport 1.3 to connect!!! is pops up in my dialog box as new hardware but when i try to connect via ecuflash Version 1.41.2483 or scantech v0.77 no cigar WTF??? im pretty sure i have all the drivers i need.
Old Mar 14, 2009 | 11:58 AM
  #547
alloutDSM's Avatar
never mind i got it to work
Old Mar 21, 2009 | 09:28 AM
  #548
mindoftw's Avatar
Can you use EvoScan as a code reader?
Old Mar 21, 2009 | 10:24 AM
  #549
LV///R's Avatar
Yes sir.
Old Mar 24, 2009 | 07:01 AM
  #550
one1fastevo8's Avatar
Does anyone know the formula for the injector duty cycle for mitsulogger or have a link to where i can find it? I have searched everwhere and i have not found no info anywhere.
Old Mar 24, 2009 | 08:54 AM
  #551
raasfaas's Avatar
I'm having the same problem...my tactrix 1.3 cable wont connect to v1.41
How did you fix the problem if you don't mind sharing.
Old Mar 27, 2009 | 01:59 PM
  #552
Mr. Evo IX's Avatar
I got a new laptop yesterday and installed ECU Flash 1.4.2483 and opened a previous map I had. Any map with more than 1 digit in it displays as 1... (fuel and mivec for example) . If I copy the map to notepad or excel the values are fine it's just a display issue. What do I need to do to fix this?
Old Mar 30, 2009 | 11:50 AM
  #553
iTune's Avatar
I can't get maptrace to work on my datalogs in v 2.6 Beta 8. The maptrace works for the sample datalogs, but not my own. I'm pretty sure i'm logging everything i would need in order to use maptrace properly.
Anybody else having an issue with Maptracing?
Old Apr 1, 2009 | 08:48 AM
  #554
Mr. Evo IX's Avatar
Got it working right after re-installing .net framework.
Old Apr 1, 2009 | 10:42 AM
  #555
mikespike2's Avatar
When I connect Mitsulogger before starting the car my coolant temp is: -54.439
Is the coolant formula not correct? After warming up it is reading 179.35.
I'm not sure what the units are.
