reading ralliart euro ecu for evo8
Old Dec 15, 2006 | 03:54 PM
gerard_fs's Avatar
Hi
I had read my ralliart euro ecu (evo8 edm) with ecuflash , and the reading proces was perfect,
but I can`t see the parameter maps.
anybody can helpme to see the maps?
ecuflash said--> the current map description is invalid or incomplete
Old Dec 15, 2006 | 08:01 PM
MalibuJack's Avatar
You need the correct definition for it.. Can you tell me what the ECUID is for it? I may have the definition you need.
Old Dec 16, 2006 | 12:53 PM
gerard_fs's Avatar
Is the genuine ralliart generic sports ecu.. for evo8 edm
its dangerous flash this ralliart rom (unreadable) to any stock ecu?
I have flashed my stock ecu with the rom read from ralliart ecu, and tested it, seems to work fine..
but I'm not sure if the afr is correct..
anybody can help me?
Old Dec 17, 2006 | 02:16 PM
burgers22's Avatar
Hi
I've read a Ralliart hex for a 7. The scale maps were in different places to my JDM ECU. Have a look on here for the thread about how to change the xml deffinition file, so you can see if one of the existing xmls will help.
Most would not recomend flashing a hex from one ECU to another. A much safer way, is to copy the map you need, say High octain ignition and paste it into your own ROM. There are far to many unknows to go flashing the whole hex file from one ECU to another. In addition you have to change the imobiliser code.
MB
Old Dec 18, 2006 | 07:19 AM
gerard_fs's Avatar
at the moment, the car is running with the stock ecu ,flashed with the ralliart rom..
EGT perfect
turbo-> 1,4bar (exactly as the ralliart original ecu)
AFR-> idem as ralliart origianl ecu
idle-> idem
rmp stationari-> idem..
It seems that it works fine
