Check out this log
Old Dec 20, 2006 | 11:53 AM
  #31
jcsbanks's Avatar
First step would be checking the fuel pressure. I know you've tried checking different widebands, but where is the sensor mounted, could there be an air leak near it? I suppose after that you need to consider getting your injectors tested.
Old Dec 20, 2006 | 11:58 AM
  #32
dudical26's Avatar
The o2 sensor is located in the mid pipe about 1ft after the test pipe. There is a stock 02 sensor located at the same angle about 2 inches in front of it, I will try switching them to make sure that the stock 02 sensor is not blocking air to the wideband. Also would an exhaust leak matter at WOT, as far as getting accurate AFR readings.
I gotta find a fuel pressure gauge and then I can see whats what.
Old Dec 20, 2006 | 12:00 PM
  #33
SophieSleeps's Avatar
if you have an exhaust leak, it causes the sensor to read lean...so that could be it.
However, you can usually tell when you have an exhaust leak. It's loud.
Old Dec 20, 2006 | 12:07 PM
  #34
RazorLab's Avatar
That is the problem with putting a wideband sensor after the DP. If you have a leak at the DP / Cat junction you can get inaccurate readings with the wideband. Having the wideband in the DP close to 12 o'clock lessens the chances of this happening.
Old Dec 20, 2006 | 12:11 PM
  #35
jcsbanks's Avatar
I know we don't go off narrowband O2 readings for good reason, but for what its worth yours is showing a higher voltage than mine is... yet my wideband says I'm running richer.
Old Dec 20, 2006 | 02:24 PM
  #36
dudical26's Avatar
I don't think I have an exhaust leak, the car does not sound like, if there is a leak it would be very very tiny.
Don't bother looking at my 02 voltage, I have a non-fouler on the sensor so it does not throw a code.
Old Dec 20, 2006 | 03:20 PM
  #37
dudical26's Avatar
Have any of you installed a fuel pressure gauge?
How do you do it.
Old Dec 20, 2006 | 03:36 PM
  #38
Nad1370's Avatar
You have a spark plug fouler on the first 02 ?? Or do you mean the 2nd 02.
Your O2 logs should be from your first 02 not the 2nd.
Old Dec 20, 2006 | 03:47 PM
  #39
dudical26's Avatar
o ok, yea the fouler is on the second 02 sensor.
Stock widebands are useless though.
Old Dec 20, 2006 | 04:59 PM
  #40
spdracerut's Avatar
Yeah, the stock narrowbands aren't very good for tuning, but not completely worthless
If you find that your fuel pressure is getting low, it may be a clogged fuel filter.
Old Dec 20, 2006 | 07:09 PM
  #41
dudical26's Avatar
I don't see how my filter could be clogged - I have 6,000 miles on the car.
What do you guys see for you AFR at idle?
Old Dec 20, 2006 | 09:58 PM
  #42
RazorLab's Avatar
It will try to maintain stoic, 14.7:1, so it will be bouncing around 14 to 15.2 or so.
Old Dec 21, 2006 | 05:38 AM
  #43
How do you do it.
Generally, the idea is simply to put in a sensor or gauge inline with the fuel line.
I don't have any experience with this fuel system but the concept is the same on all cars.
You can get T fitting and send one end to your sensor/gauge.
Old Dec 21, 2006 | 09:28 AM
  #44
Ralph's Avatar
I'm just glad to know the stock fuel system with a walbro will be sufficient for 380hp (dll dyno) .
Old Dec 21, 2006 | 10:57 AM
  #45
dudical26's Avatar
I suspect I may have an exhaust leak because my AFR at idle is 16 on the wideband. What is the 02 voltage supposed to be at idle?
I think a small leak may throw off my AFR readings slightly about 1.5 at idle and maybe .5 or so at WOT.
