View Poll Results: Which scaling type do you use?
AFR
12
100.00%
int8
0%
hex
0%
other...
0%
Multiple Choice Poll. Voters: 12. You may not vote on this poll
AFR Map scaling values when tuning
Just out of curiosity, when you are tuning your AFR values, what scaling are you using on the fuel maps, and why are you using that particular scaling?
If you don't know where the scaling values are set, then you are probably using the default value of AFR.
anyhow, happy new year everyone!
keep the rubber side down!
Originally Posted by AlwaysinBoost
I don't understand the question
Um default, what is the advantage of going to something else? This isnt being sarcastic, I dont understand why I would need to change seeing things in target AFR to something else.
The only reason you might want to change from the current scaling is simply to avoid confusion.. What I did was spend my time scaling my injectors so my actual AFR's closely resembled the AFR's in the ECU Maps. Sometimes I just switch to Hex to abuse myself, considering I know that 14.7 is 80 in hex, which is 128 in int8, which is the "middle point" of the maps values..
