Mitsulogger v1.5 - Can it be?
Old Jan 4, 2007 | 12:25 AM
MalibuJack's Avatar
Okay, considering Mitsulogger V2 is getting a complete rewrite to accomodate a new flexible architecture, I will be releasing a v1.5 of mitsulogger, likely by the end of January..
What is so special about it? Well, Wideband support, otherwise it won't be altered much.
Zeitronix ZT-2 logging, with support for all of its output, not just AFR, but AFR, Lambda, MAP, EGT, and its additional inputs.
TurboXS Tuner, also with support for all of the additional data if you have the Tuner Pro, otherwise AFR (possibly Lambda) for the Tuner
Synchronized logging if you have the TurboXS UTEC, plus it will grab the AFR and other data you want from the UTEC logs and embed them into the Mitsulogger logs.
I wanted to get something out there for the hardware that is currently overlooked.
There will also be a few minor fixes, the most notable is the software will now work correctly even if you have a Serial device that is recognized as an FTDI device and conflicts with the Tactrix cable.
Like I said, I'm hoping to get this out in 2 weeks, but more likely by the end of the month, partially because the code for the Widebands is shared with the V2 Plugin architecture and works with both.
Also, the future Mitsulogger v2 will be renamed Unilogger as its designed as a framework and Mitsulogger is now a plugin for it. Basically its a data aggregator that will collect loggable data from Plugins, and output the data to other plugins such as a logger, map tracer, dashboard, video overlay, etc.. The intent was to support different cars, Engine management, etc, using different plugins and create a configurable and usable output.
Old Jan 4, 2007 | 06:17 AM
A418t81's Avatar
Sounds awesome Jack, thanks for all your hard work. Happy new year to you.
Old Jan 4, 2007 | 06:39 AM
honda-guy's Avatar
will it support LM-1 wideband.
Old Jan 4, 2007 | 06:46 AM
sandm's Avatar
way to go jack...
you rock
Old Jan 4, 2007 | 07:07 AM
dryad001's Avatar
Nice to know Jack.
Old Jan 4, 2007 | 07:15 AM
cij911's Avatar
YOU ROCK!!!!
Old Jan 4, 2007 | 07:17 AM
04WWRS's Avatar
and/or AEM. Thanks for all your hard work on this!!
Old Jan 4, 2007 | 08:36 AM
MalibuJack's Avatar
I have an LC1, and will be working with them to implement their MTS component which should work with the LC1, LM1, and their other logging devices, I will attempt to at least get the MTS stream and channel information as then any Innovate MTS device can be logged with it.. However, I will add support for any devices that I can get in my hands to work with in future releases.
Since the TurboXS Tuner and Zeitronix devices are currently not supported by anything, I figured I'd get those out first.
Once the new 2.0 app is ready, then the support can be added as new plugins and wont require new releases.
Old Jan 4, 2007 | 08:41 AM
TTP Engineering's Avatar
Badda-Bing... Unilogger it is...
Good stuff Jack. Thanks for your contributions!
Old Jan 4, 2007 | 09:03 AM
MalibuJack's Avatar
Yeah, having hardware in hand cuts development time down significantly, even more when I can run the hardware on a bench to get the code working initially.
Old Jan 4, 2007 | 09:10 AM
curisu's Avatar
Looking forward to this Jack! Thanks for putting all this time and effort in!
Old Jan 4, 2007 | 09:13 AM
UpstateEVOVIII's Avatar
I appreciate all of your hard work and look forward to trying out your products on my IX. Lots of reading to do to learn up on it now!
Old Jan 4, 2007 | 09:18 AM
MalibuJack's Avatar
BTW, can someone attach a log file from a TurboXS TUNER, not a TUNER PRO, using SHIFT-1
I want to be sure the log files are exactly the same.
Old Jan 4, 2007 | 09:22 AM
Mike01gsr's Avatar
[QUOTE=MalibuJack;3823177]Okay, considering Mitsulogger V2 is getting a complete rewrite to accomodate a new flexible architecture, I will be releasing a v1.5 of mitsulogger, likely by the end of January..
Zeitronix ZT-2 logging, with support for all of its output, not just AFR, but AFR, Lambda, MAP, EGT, and its additional inputs.[QUOTE]
This is awesome I can't wait. Thanks for all your hard work!!
Old Jan 4, 2007 | 09:46 AM
BADEVO's Avatar
Once again Jack proves he's worth his weight in Data logs to the community! Thanks you sir!
