Which ignition map to change?
Old Jan 5, 2007 | 06:39 AM
Markley02's Avatar
I did try to search and I couldn't find anything.
When reading through the beginners thread they are working on an Evo VIII. When I pulled the ROM from my IX there are a total of 6 ignition maps, not the 2 that are shown in the beginners thread. Which map does the car use and when?
Thanks
Old Jan 5, 2007 | 06:50 AM
Chino1's Avatar
what are they listed as?
Old Jan 5, 2007 | 07:26 AM
20psiMR's Avatar
Change high octane ignition map 1, then copy and paste your changes to the other 2 high octane ignition maps. Thats what I do. Generally its said that the car uses map 2 mainly so thats the one to change. They are all the same from the factory, so I dont see the harm in changing all 3 high octane ignitions. Just leave the low octane maps alone.
Old Jan 5, 2007 | 07:32 AM
Chino1's Avatar
all ive ever changed was "ignition map 1" i guess i will start changing all the other "high octane ignition maps"
Old Jan 5, 2007 | 07:56 AM
Markley02's Avatar
They are not the same from the factory.
Old Jan 5, 2007 | 08:52 AM
NIevo's Avatar
Wheres the beginners thread? I need that!
Old Jan 5, 2007 | 08:54 AM
EvoAnthony's Avatar
Here you go!
https://www.evolutionm.net/forums/sh...d.php?t=201146
Old Jan 5, 2007 | 09:06 AM
NIevo's Avatar
Originally Posted by EvoAnthony
Thank you
Old Jan 5, 2007 | 09:13 AM
bigric09's Avatar
they definitely are not the same from the factory....map 1 is for when the car is not at operating temp., map 2 is normal conditions operating temp reached and map 3 is limp mode map .... this is how i have understood things from posts in the past...
Old Jan 5, 2007 | 10:32 AM
RazorLab's Avatar
Changing map 1 and map 3 to be the same as map 2 is a good way to put holes through your block. Espically map 1
Old Jan 5, 2007 | 11:06 AM
JohnBradley's Avatar
Ahh whats yo problem Bryan, you dint win...Woooo. But for serious, is that one of yours or some other unfortunate souls?
Topic- Change only the High octane map 2. This actually goes for any of the maps that have multiple examples. Boost is the same way, #2 is operating temp all conditions green.
Old Jan 5, 2007 | 11:41 AM
Markley02's Avatar
Thanks guys!!
Old Jan 5, 2007 | 12:08 PM
NIevo's Avatar
Ouch!! How could you tell something was wrong?
jakgal04
Sep 20, 2017 08:09 PM
EFIxMR
Jan 1, 2015 05:27 AM
RoadSpike
Lancer Engine Management / Tuning Forums
36
Sep 12, 2014 08:33 AM
sekula
Aug 25, 2009 12:51 PM
Mikey986
Oct 30, 2004 11:15 AM
