Is my tune safe for a long road trip?
Old Jan 5, 2007 | 08:43 PM
4WS Tuning's Avatar
what are your mods?
Old Jan 6, 2007 | 01:16 AM
ace_2822's Avatar
Hks intake, Ams licp, Ams Intercooler, Walboro 255, and Ams catback,
Old Jan 6, 2007 | 01:18 AM
4WS Tuning's Avatar
thats gonna be pretty nasty on a stock map...
have you logged your mods with the stock map?
ace_2822's Avatar
Originally Posted by JohnBradley
What are your mods, and if it includes a 255L did you buy the install kit or no?
I did not buy the install kit.
Old Jan 6, 2007 | 01:20 AM
ace_2822's Avatar
No not untill i did my base flash, It was hitting fuel cut. I babied it
Old Jan 6, 2007 | 01:21 AM
4WS Tuning's Avatar
if ya cant get a quick map asap i would go pick up any mbc you can find and just leave it as low as needed to cure the super knock.
just start logging at wastegate... then click it up a few pounds and see what ya get and work it that way.
jestr's online pretty early and he can make ya a map pretty fast if hes not slammed
his screen name for aim is "jestrtuning"
cheers!
Old Jan 6, 2007 | 01:30 AM
ace_2822's Avatar
I have a mbc thats not installed
Old Jan 6, 2007 | 11:42 AM
JohnBradley's Avatar
I will put dollars to pesos that you are running WAY LEAN. Check your IDC's. I have seen them as low as 52% because of improperly installed 255L. I reccomend first tossing the stock pump back in, or if its an VIII, finding a stock IX pump if you cant buy the install kit in short order.
Old Jan 6, 2007 | 01:05 PM
chmodlf's Avatar
Downpipe hitting cross bars?
Old Jan 6, 2007 | 03:35 PM
jmoudry's Avatar
What does your AFR look like when you are getting the knock counts? I wouldn't replace the fuel pump until you have data to support it being the issue. Like high AFR values under heavy load that could also be the tune.
Old Jan 6, 2007 | 04:24 PM
ace_2822's Avatar
Downpipe is hitting the crossbar. Thought of that today at work today. That would Make the knock sensor go crazy right? Also would mess with the timing right? hope thats it.
Old Jan 6, 2007 | 04:26 PM
bluebyu36's Avatar
put in the boost controler
Old Jan 6, 2007 | 05:26 PM
ace_2822's Avatar
I leave tommorow, Fixed the downpipe rattle. Still knock, Whats the deal? anyone that can take a look at my logs? I would post them but im having problems.
Old Jan 6, 2007 | 06:15 PM
ace_2822's Avatar
Now my knock count is down to 2,3 and a Two 6s but Nothing higher. Is that ok?
