EvoScan help
Old Jan 13, 2007 | 03:11 PM
XK120's Avatar
EvoScan help
So I just recieved my Tactrix cable yesterday and I've gotten Mitsulogger to work just fine...however, after downloading EvoScan today, it doesn't seem to recognize the cable...it says "USB device not responding". I've tried everything from restarting the laptop to changing which USB port the cable is plugged into...no luck. Is there something else that I have to do to get it to work? Thanks
Old Jan 13, 2007 | 03:13 PM
4WS Tuning's Avatar
install ecuflash again and make sure you install the cable...
cheers!
Old Jan 13, 2007 | 03:14 PM
XK120's Avatar
already installed the cable drivers...it works fine with Mitsulogger...
Old Jan 13, 2007 | 03:21 PM
4WS Tuning's Avatar
i would do it again... i had the same problem... reinstalled it and it was fine
Old Jan 13, 2007 | 03:57 PM
XK120's Avatar
Fixed it! Turns out the Tactrix driver wasn't installed right the first time...anyways a bit OT but do I need to buy DataLog lab to get a hp/tq graph?
Old Jan 13, 2007 | 04:05 PM
Soon2BEVO's Avatar
I downloaded EVOscan and got my tatrix cable and was getting same problem. I went back and installed ECUFLash, retarted the computer then went out and hooked it up to the car and it worked.
EDIT just saw you fixed it!
Old Jan 14, 2007 | 11:07 AM
High_PSI's Avatar
where is the link for Evo Scan?
Old Jan 14, 2007 | 11:32 AM
Mellon Racing's Avatar
www.openecu.org downloads
Old Jan 14, 2007 | 11:49 AM
JohnBradley's Avatar
Actually EvoScan is this link-
http://www.limitless.co.nz/EvoScan/
Old Jan 14, 2007 | 11:55 AM
4WS Tuning's Avatar
lol told you...
i dont get why ya need to reinstall it everytime there's a new program that use's the cable....
when you install datalog you're gonna need to reinstall it again....
evoscan should be coming out with a new version shortly that will have the dyno built in
cheers!
