how much is acceptable? knock
Old Jan 20, 2007 | 11:47 AM
ApexVIII's Avatar
how much knock do you guys tune for and say its safe? i know that 0 is the target. but do you tune untill you get to like 2 counts then back off the timing?
also does any one know any helpful ECUFlash tuning websites?
Old Jan 20, 2007 | 11:53 AM
mac_05evo's Avatar
Anything under 3 is pretty normal, and happens on occasion, anything over 3 but under 10 or so, isn't anything to be hugely alarmed at, but it will affect your tune. Ultimately you want to keep those counts at zero if at all possible. Just have to keep them as low as possible.
Check the forums, they have TONS of useful info..
Old Jan 20, 2007 | 12:03 PM
inco9nito99's Avatar
Depends on how aggressive your a/f and timing maps are.
Old Jan 20, 2007 | 12:17 PM
ApexVIII's Avatar
ok this is a screen shot of my stock ECU on top and one that some one made for a evo(not made for mine) and i guess its a good starting point
i will be running off of 91 gas. how does this look? i dont have a WB AFR, so i wansn't going to go as lean but maybe lean mine out by like 2-3 tents in the upper RPM's cus my last log i was at 101% IDC's
Old Jan 20, 2007 | 01:51 PM
jcsbanks's Avatar
That modified fuel map looks horrid. Very lumpy, and leaner than I like in the midrange.
Original one probably just needs leaning out in the 5000+ range. Do it with a wideband or leave it stock.
Old Jan 20, 2007 | 02:03 PM
ApexVIII's Avatar
ok thanks ill leave it stock untill i get a wb or a tune
Old Jan 20, 2007 | 04:13 PM
burgers22's Avatar
ApexVIII;388213also does any one know any helpful ECUFlash tuning websites?
Er, here? Glad to have you aboard! Get that wideband going and take it easy.
MB
Old Jan 20, 2007 | 11:32 PM
RazorLab's Avatar
I would not run that fuel map without a wideband. Actually I wouldn't run that fuel map with a wideband either.
Live4Redline
Jul 17, 2024 07:09 AM
jOhn-e
Jun 15, 2013 11:56 PM
Nomad4g63
34
May 11, 2009 05:49 AM
cbrtrx
Sep 8, 2006 09:01 PM
racegate
AEM EMS
Jul 17, 2005 01:35 PM
